Another sony led back lighting problem.
  • AMRivlin
    • Jun 2014
    • 13
    Re: Another sony led back lighting problem.
    Originally posted by bammbammfran
    how many separate bulbs board strips are on that screen ? 4 ?
    how many plugs pins are on each plug of each strand or 63 ? 14 ?
    can you post a few pictures ?
    did you try hooking it up to see whichstrip had the trouble bulbs ?
    I usually change the bad bulbs ?
    I did find one used strip here but the plug might be in the wrong direction
    http://www.iccfl.com/product_info.php?products_id=21543
    I just enlarged those pictures and it looks like you probably have two version boards
    one version has the plug on one end and the other has it on the other end
    and it has 9 3 volt bulbs on each strand.
    so probably they are staggered like bulb 1-8-15-23-30 etc will be on one strand and 2-9-16-24-31 etc on another
    you can check one bulb at a time using a 3 volt battery or all 9 on the strand at once using a 24 volt power source (19 volt laptop adapter might just be enough to do it- if not it will do 7 at a time)
    bulbs have a positive and negative side and will only light in one direction, so you have to figure out which way the first bulb of the strand travels first since some strands might have the positive side towards the main plug and some might be the reverse and start at the opposite end.
    MAN! I think this is it!!! (I accidentally destroyed the broken led strand trying to remove the bulb, so i will buy this and pray i can reassemble the tv properly.)
    How did you source it? I couldn't locate/google it to save my life.
    Here are 2 photos:
    • bammbammfran
      • Apr 2014
      • 476
      This will work, but you have to watch your brightness depending on how many bulbs are in each string.
      For instance, the apples have 20 bulbs per sting so removing one bulb would raise the other bulbs 0.15 volts higher than normal which isn't too bad. But, On a 9 string bulb setup like the one in this post, the voltage would go up 0.375 volts per bulb and that is too high for long term at high brightness.
      • bammbammfran
        • Apr 2014
        • 476
        [/IMG]
        you should have asked before trying to remove a bulb !!
        These usually have a heatsink underneath them that is soldered down, so they need to be removed with a heatgun.
        First you have to cover the nearby bulbs with a few layers of foil and then you have to apply flux to the bulbs and then heat it till you see the solder glisten.
        IF, you have a real good soldering iron and if you are not trying to salvage a bulb, they can be removed with that, but you first have to snap or carve the top of the bulb yellow off so that you can heat right down on the bulbs metals easier. again , flux needs to be used
        if you are not trying to salvage a board, but you want to salvage bulbs or transplant then do not use foil and heat as much as you can from the bottom of the board
        • AMRivlin
          • Jun 2014
          • 13
          Followup.
          I ordered this Part http://www.iccfl.com/product_info.php?products_id=21543
          It was the A side. But I needed the B side.
          When the shipment arrived (7 days from time of order) it was actually the B Side they shipped. Weird.
          I reassembled the tv, ended with 5 extra screws. whoops. Turned on the TV and VIOLA, it works. all LEDs on and no autoshut downs.
          What a learning experience. Overall I spent $54 in parts/shipping, but I am very pleased with myself.
          Thanks to everyone on here for their assistance and inspiration (seriously)
          You showed me a repair was feasible! "Hat Tip"
          • bammbammfran
            • Apr 2014
            • 476
            It is not weird that they sent the wrong side.. They are just another seller that does not know what they are doing !
            LUCKILY, their mistake worked out good for you and saved you some extra work.
            Glad to hear that you got it back together and are running again !!!
            • crackedprint
              Sony HCD-HX80R Amplifier Volume Control Problem
              by crackedprint
              I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
              I have tried a Cold Reset as per the service manual.
              I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
              I have looked all the way through the service manual and tried many online...
              01-21-2025, 12:18 PM
            • retrorepair
              SONY KDL-40P3600 Picture Problem
              by retrorepair
              Hello gurus, hope you can assist me...
              I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
              I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
              Thanks in advance.
              10-11-2024, 05:12 PM
            • guruji
              Sony mbx-266 problem
              by guruji
              Hello
              I this Sony mbx-266 it powers
              on all the voltages are normal the strange part iOS the caps key num key works which shows the machine has booted but no video at all internal dp and the ext vga or hdmi.I have changed the bios but same issue. What do I check ??
              07-25-2025, 08:10 AM
            • ivtec
              sony kdl 32 bx 300 turns off and back on help
              by ivtec
              Hi my old Sony i turn it off and it turns itself back up and many times remote wont work have to unplug tv...
              07-03-2024, 10:52 AM
            • boyebaran
              hisense 65k560 back light problem
              by boyebaran
              hi to all
              tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
              in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
              please advise me tnx
              05-20-2025, 07:11 AM
