L.G. 42PC1D, dark flickering pic.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: L.G. 42PC1D, dark flickering pic.
    Yes--Once Great Makers de-evolved into re-badging utter crap--Very sad really!
    I used to work at Hitachi dealers in early 80's the sets were good. We used to service the likes of the CNP190, these things Barely ever went wrong--only mechanical wear of the push-button tuner, --after 20 years--then, still good.
    Picked an earlier one up a year back--a CSP-470 from 1974, Its Still Working today!
    Sorry to go o/t, Normal service will be resumed tomorrow eve when I dig the scope out!
    TELEFIX
    • Clydeuk
      • Jan 2012
      • 193
      I worked for Comet service until the hammer fell on that company, they sold a huge number of JVC badged sets right up to 42 inch, made by Vestel. While I'll agree it's cheap crap they are at least pretty consistent with failures, which seem to have been worse the newer the chassis. Power supply as always with Vestel is a weak point, and can damage other areas when it fails.
      I have to say due to the hectic nature of that job I never had any chance to delve in deep, I have since leaving discovered a whole lot more about them.
      They can give a decent display despite the poor quality design, 32 inch and below anyway.
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        OK, Ive dug the scope out and checked the waveforms.
        Y-sus appears a fair facsimile of whats in the manual, but the sharp spike downwards of the positive going ramp has a flat bottom of approx 10us.
        Its approx 250V at its peak from the '0' v line.
        the wave is fairly stable and constant.
        The Z-sus wave is rather similar in shape, but the positive ramp doesnt climb to a peak then return sharply to 0v, but has a rounded off part after the downward spike (neg going square-wave block) climbing again and a flat top, of 90V in relation to '0'V.
        There's a lot of messing round going on with the Z-sus waveform, not stable or constant--'stuff' going on in the background is the best I can say....
        Z-sus IPM is stone cold after half-hour while Y-sus is warm.
        Does the above confirm Z-sus IPM failure?
        My old scope absolutely Hates these waveforms and its rather difficult to see/sync on them--Let alone take any pics of 'em!
        TELEFIX
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          If you reckon it is the IPM--where would be the best place to get one? --Seem to be a lot around of dubious origin!
          TELEFIX
            Does your scope have a line trigger? Feed the set with ~50Hz video and sync off 50Hz mains. It's not perfect, but it's good enough to have a quick look.
            (Panel refresh is about 10 x input frame rate, no frame conversion is done.)
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              #26
              Better still--I could sync off the video sync from external source....
              Cant remember--set is put away at the mo, but I think there's a video O/P, could sync off that, or as you say--feed off a SCART etc....
              Didn't think of that (Doh--What a dumbo!)--Cheers Tom!
              TELEFIX
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                #27
                OK then--I'm fairly convinced its the IPM what with the readings and scope-checks, plus the fact its stone-cold......
                Ive got a 50PDPX3 chassis at work--but this uses two IPM per board, a J015C and a J016C.
                The 42 uses a single J018C....
                I'm wondering if either of the above would be suitable as a replacement. I cant find any datasheets or anything on any of them though....
                Anyone got a spare good YPPD-J018C (Or even a complete working Z-Sus) want to swap some parts/boards for? Ive got lots of different make/model etc to choose from--Probably more than those iffy sellers on fleagay!
                TELEFIX
                  AFAIK, the IPMs are not compatible. On 50" chassis, one is ERC, other is SUS. On 42" chassis, one IPM does both ERC and SUS.
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    #29
                    Ah--Aint That typical!
                    TELEFIX
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      #30
                      Well--I've got two sets now--One at work a 50" (50PC1DA) and the set I have here--Both have much the same flicker in the screen and similar voltages etc. Ive yet to check to 50" waveforms, it was getting late, had to shut the shop--and the ever present distraction of customers stopped me checking waveforms today....
                      This thread, Tom had a tussle with a 50" with the grey flickering screen--
                      https://www.badcaps.net/forum/showth...hlight=50pc1da
                      In the end, it was his ERC IPM and buffer-chips causing problems.....
                      --I'm hoping the buffers are OK on my 42" but looks more and more like the IPM's are my troubles with that one.
                      Guess I'll have to stump up and buy a couple, unless anyone can suggest anything more to test.
                      --Not sure what to do with the 50", Guess I'll shove it back in my tin-shed at work--with all the other sets Ive got spares issues with!
                      TELEFIX
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        #31
                        For the record--I repaired the IPM in a thread here--
                        https://www.badcaps.net/forum/showthread.php?t=34766
                        Buffers were OK thankfully.
                        TELEFIX
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          #32
                          The set now has 25 hours on its repaired IPM, with a computer case (quiet) fan added over each IPM heatsink for cooling.
                          Firmware has been updated to remove the Mal-Discharge or red-dots it had a severe case of.
                          So far--so good.....
                          TELEFIX
                          • adamp91gvm
                            • Jan 2014
                            • 706
                            • uk
                            #33
                            Sorry to jump in on your post but I have the same tv that has no pic at all would it be easier to start a new post ?
                            • Alastair E
                              Chief Womble
                              • Mar 2013
                              • 1963
                              • U.K.
                              #34
                              Well--Seeing same set, you could carry on this one if you want....
                              What tests have you done? Anything on the screen at all--in darkened room?
                              TELEFIX
                              • adamp91gvm
                                • Jan 2014
                                • 706
                                • uk
                                #35
                                Nothing I have narrowed it down to the y sustain the voltage is up and down when it's plugged in but when disconnected voltage from the power board is level
                                • Alastair E
                                  Chief Womble
                                  • Mar 2013
                                  • 1963
                                  • U.K.
                                  #36
                                  Have you tried it with the Vs fuse Out on first, Y-Sus, then Z-Sus...?
                                  Set will trip out if there's no 5V to the Y-Sus board--as in pulling the plug, I think the Control-board sources 5v from there....
                                  TELEFIX
                                  • adamp91gvm
                                    • Jan 2014
                                    • 706
                                    • uk
                                    #37
                                    In fact it seems to be when the t con is connected to the y sustain just taken the ribbon out of it and everything is level and constant
                                    • Alastair E
                                      Chief Womble
                                      • Mar 2013
                                      • 1963
                                      • U.K.
                                      #38
                                      Are the three or four temp LED's lit on the Control-Board?--Usually three if its cool, two if very cold
                                      TELEFIX
                                      • adamp91gvm
                                        • Jan 2014
                                        • 706
                                        • uk
                                        #39
                                        Yer there is only 2 on
                                        • Alastair E
                                          Chief Womble
                                          • Mar 2013
                                          • 1963
                                          • U.K.
                                          #40
                                          Ok--Thats fine, control-board active, doing something anyway!
                                          Have you a scope?
                                          TELEFIX
                                          • Rozp
                                            70LE660U dark cloud or black screen with sound.
                                            by Rozp
                                            Hello Everyone,
                                            This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                            I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                            08-29-2023, 05:25 PM
                                          • reessi
                                            ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                            by reessi
                                            The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                            They are black on the right and gradually fade to nothing on the far left.
                                            They start either after 5 mins or up to 2 hours after so annoying for testing.
                                            They flicker continuously very fast! With a slight pause milli-second every second.
                                            Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                            I tested each half by removing the first the left flex from...
                                            06-03-2025, 09:58 AM
                                          • bo_vest
                                            LG 42PC1D (PDP42X30401) wiht flickering image and Vzb high
                                            by bo_vest
                                            Hello. I wonder if any of you guys may be able to point me in the right direction here.
                                            My 42PC1D (PDP42X30401) always had some red dots on black background. It never bothered me too much. One day it died (switched off)
                                            I replaced the Y-SUS board and it worked for a few days. After a few days I started getting grainy image when the set was cold. As soon as it warmed up it worked. The graining got worse and worse until it stopped working. Now I get flickering white dots. I can just about make out the menu on the screen so I know the TV as such is working because the menu...
                                            04-06-2021, 09:47 AM
                                          • DrvLikHell
                                            Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
                                            by DrvLikHell
                                            Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
                                            The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
                                            07-05-2024, 02:54 AM
                                          • Lintesir
                                            Panasonic P42S30 Plasma - Pink sparkles
                                            by Lintesir
                                            My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                                            There is about a 5cm high region at the top without any sparkles,...
                                            07-26-2024, 03:16 AM
