lg 50ps3000 flaashes then screen goes off
    Re: lg 50ps3000 flaashes then screen goes off
    That circuit with the adjustment could have a short circuit. There's a repair kit:
    http://www.ebay.co.uk/itm/LG-50PS300...item417bcc2e87
    which includes some FETs, resistors, etc. There may be a part listing elsewhere.
    That is for red pic - i.e. dead Z-sustain Vzb and other components. The fault may be limited to those heatsinked transistors near Vzb adjust on Z-sustain.
    No schematics, though.
    • wreksta
      • Aug 2013
      • 508
      • england
      Tom I fitted that kit I have no shorts all connections are made so what else could could I check plz
      I can tell you this that ceramic resistor in repair kit would light up and make a frazzling noise like a short but I replaced with original one I took out and I didnt get that short or lighting up
        Picture of the Vzb adjust area? You will probably find a FET on the nearby heatsink is short. The way most plasmas Vzb work is by linear regulation of Vs - they drop voltage across a transistor, which produces a small amount of heat. If transistor shorts, the Vzb = Vs minus a small drop due to resistance (that ceramic resistor, and some other parts.)
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          does the original resistor you put back in test ok and not gone open circuit?
          • wreksta
            • Aug 2013
            • 508
            • england
            Original resistor tests fine mate now I cant get ysus to fire up im sure it did with zsus disconnected could high ve have killed the ymain if so what to test on y for diagnosis ? Thanks
              Vzbias / Ve is independent of Y-main. However, running it on extreme brightness for too long could have damaged the Y-main from too much power usage. Standard checks: IGBTs/FETs on heatsinks and -Vy/Vsc voltage (see panel diagnosis sheet I linked previously.)
              • wreksta
                • Aug 2013
                • 508
                • england
                #27
                Thanks will check in the morn
                • wreksta
                  • Aug 2013
                  • 508
                  • england
                  #28
                  Funny thing tom I can remember now the tv would stay on with a very very grainy red hazy pic right until I switched input to hdmi then nothing except the flash when powered
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • smic717394
                    by smic717394
                    07-25-2024, 10:16 AM
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • ipatch
                    ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                    by ipatch
                    i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                    08-24-2024, 02:36 PM
                  • FreakyMex
                    Trouble to identify part (Lunii screen) for replacement
                    by FreakyMex
                    Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                    I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                    02-17-2025, 01:16 AM
