lg 50ps3000 flaashes then screen goes off
    Re: lg 50ps3000 flaashes then screen goes off
    That circuit with the adjustment could have a short circuit. There's a repair kit:
    http://www.ebay.co.uk/itm/LG-50PS300...item417bcc2e87
    which includes some FETs, resistors, etc. There may be a part listing elsewhere.
    That is for red pic - i.e. dead Z-sustain Vzb and other components. The fault may be limited to those heatsinked transistors near Vzb adjust on Z-sustain.
    No schematics, though.
    • wreksta
      • Aug 2013
      • 508
      • england
      Tom I fitted that kit I have no shorts all connections are made so what else could could I check plz
      I can tell you this that ceramic resistor in repair kit would light up and make a frazzling noise like a short but I replaced with original one I took out and I didnt get that short or lighting up
        Picture of the Vzb adjust area? You will probably find a FET on the nearby heatsink is short. The way most plasmas Vzb work is by linear regulation of Vs - they drop voltage across a transistor, which produces a small amount of heat. If transistor shorts, the Vzb = Vs minus a small drop due to resistance (that ceramic resistor, and some other parts.)
        • vinceroger69
          • Mar 2012
          • 6714
          does the original resistor you put back in test ok and not gone open circuit?
          • wreksta
            • Aug 2013
            • 508
            • england
            Original resistor tests fine mate now I cant get ysus to fire up im sure it did with zsus disconnected could high ve have killed the ymain if so what to test on y for diagnosis ? Thanks
              Vzbias / Ve is independent of Y-main. However, running it on extreme brightness for too long could have damaged the Y-main from too much power usage. Standard checks: IGBTs/FETs on heatsinks and -Vy/Vsc voltage (see panel diagnosis sheet I linked previously.)
              • wreksta
                • Aug 2013
                • 508
                • england
                #27
                Thanks will check in the morn
                • wreksta
                  • Aug 2013
                  • 508
                  • england
                  #28
                  Funny thing tom I can remember now the tv would stay on with a very very grainy red hazy pic right until I switched input to hdmi then nothing except the flash when powered
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • smic717394
                    by smic717394
                    07-25-2024, 10:16 AM
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • ipatch
                    ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                    by ipatch
                    i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                    08-24-2024, 02:36 PM
