OKI V32B-LED2 LED TV bright pink display with green horizontal line up
  • eddiesomesan
    • Feb 2011
    Hello. I need some help in repairing a friends TV, OKI V32B-LED2
    The TV starts, but when the image appears, all I can see is a bright pink image with a 3 centimeters green horizontal line in the upper side of the LCD.
    Also, there are some rare point like pikels all over the screen. (see pictures).
    I have tried reseating all the cables but no result.
    At first look, the power supply and the rest are ok, and nothing gets too hot.
    When I push the buttons on the tv (touch buttons), I can hear a beep every time I touch one of them but on the screen nothing appers. Also, on the remote, whatever I push, I have no reaction from the TV, except the power button which stops the TV.
    I don`t know where to start with the repairing and I hope someone from here can guide me.
    Thank you.
  • eddiesomesan
    • Feb 2011
    Re: OKI V32B-LED2 LED TV bright pink display with green horizontal line up
    Thank you.
    Anyone?
    • jimjoe123
      LCD TV Green/Pink screen problem
      by jimjoe123
      I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
      Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
      Then each time...
      02-23-2020, 01:29 AM
    • cubytus
      Samsung UN50TU8000FXZC shows thin horizontal green line when warm
      by cubytus
      Hi to all,
      I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
      I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
      Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
      01-10-2024, 01:26 AM
    • Ihandyrepair
      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
      by Ihandyrepair
      Hi guys
      I just started fixing 4k TV few months ago. so I am still learning a lot
      I got this tv from friend complaint is ghosting or horizontal lines on image.
      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
      then it started to show the ghosting white image.
      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
      it has 3 thin small boards at the bottom of the...
      12-05-2022, 04:18 PM
    • arctor
      samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
      by arctor
      hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
      04-26-2025, 05:22 AM
    • labello
      Lg43UJ620V horizontal line
      by labello
      Hi guys I have this tv and in one side of the pannel it shows some line i also cleaned the camble notting, although I found an smd capacitor on the pcb (there's no tcon on this model) but I can't find the same model thanks
      02-20-2025, 02:52 AM
