Onn 100012587
  • x_orange90_x
    • May 2015
    • 702
    Onn 100012587
    I just got a 65" Onn 100012587 and the guy thought the backlights were bad. He took it apart 😔 I looked in it and see he removed the connectors on both LED strings, so I can't really plug them back in. I looked for an image on the screen but noticed possible vertical lines. I'm thinking of putting 9v batteries in series and connecting each LED string to see if it'll light up and show me what the screen looks like. I've done this before and it worked, but that was with individual pairs of strips. If I do say 5 batteries (45v), would that at least dimly light a while string enough to see the screen?
  • x_orange90_x
    • May 2015
    • 702
    I looked at replacement strips and each LED is 3v and there are 28 in each of the two strings. That comes out to 84v. If I use 6 batteries that would be 54v, at 1.92v/LED. That should be enough to light them up, correct?
    • lotas
      • Jan 2016
      • 4475
      • Russia
      LEDs are powered by a current of 150 - 400 mA, but how much current do your batteries produce? No matter how they burn them!
      • EazyBone
        • Jun 2023
        • 1306
        • United states
        You should just invest in a LED tester. Can get a cheap one like 20 bucks. You seem to be doing a lot of tvs, it's one of the best tools to have because eliminate something within a minute.
        • x_orange90_x
          • May 2015
          • 702
          Nothing negative happened when I tested individual pairs this way. However, a resistor is typically used to control the current. I just want to see the condition of the screen. I don't care about the lights at this point, because I'm expecting they are faulty anyways.
          The batteries are carbon zinc Heavy Duty from Dollar Tree, rated at roughly 400mA. I'm not concerned about current, just enough voltage to light them enough to see the screen.
          Can you test entire strings with those?
          Edit: nvm, I found one on Amazon and it says it goes up to 300v. I will probably pick one up in the near future, but for the time being I'll probably get the batteries.
          • EazyBone
            • Jun 2023
            • 1306
            • United states
            Yes you just shove the probe in and it lights em up. This is my most used item after my multi meter. Basically the 2 most useful tv fixing items. It's $20 don't be a cheap and buy one
            • x_orange90_x
              • May 2015
              • 702
              I will get one soon, just not today for this tv. I have a feeling I'll be throwing it away tomorrow night anyway if the screen looks anything like I imagine it does
              • x_orange90_x
                • May 2015
                • 702
                Well I tried with 6 and then 7 batteries. Didn't get so much as a blink on either string. At 64v I don't understand why they didn't light up even a little.
                • EazyBone
                  • Jun 2023
                  • 1306
                  • United states
                  Because you use ghetto rig. Both can be dead though, generally in my experience one string is dead though. With these there is 2 sets so one goes out before both die. So one should work.
                  • x_orange90_x
                    • May 2015
                    • 702
                    If money wasn't tight at the moment I'd order a tester. I will soon though.
                    • x_orange90_x
                      • May 2015
                      • 702
                      I got a tester and tried it last night. No lights at all. Tried on an old strip I had laying around and it lit up. I'm thinking the guy ripped the connectors off so he could *gulp* attach the leds to an external power source.. And subsequently fried every one.
                      • x_orange90_x
                        • May 2015
                        • 702
                        Has anyone ever had luck shining a bright enough LED through a back hole to light up stove of the screen? At this point I can't invest a dime in this set because I know for a fact there are thin colored vertical lines on the screen, I just can't see how close together or how far they span. If I could light up at least a small portion i think I could tell if it's a panel issue or sharing with the TCON.
                        • EazyBone
                          • Jun 2023
                          • 1306
                          • United states
                          It's the panel. Toss it. Or use a very strong flashlight and shine it on the front in a dark room.
                          Glad you got a led tester though, will save you tons of time.
                          I have this flashlight and it's bright enought that you can see everything you need on the screen.
                          https://www.amazon.com/gp/aw/d/B092Z...b_b_asin_title
                          • x_orange90_x
                            • May 2015
                            • 702
                            I discovered that the screen is cracked and that's why there are all of the colored lines, which I suspected would be the case. Backlights are fried and the screen is cracked, so I'm just pulling the boards out and tossing the rest.
                            • carrzkiss
                              Cyberpower cps1500avr not charging batteries
                              by carrzkiss
                              Hello, all.
                              Cyberpower Battery Backup Unit.
                              I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                              When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                              In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                              Checking the voltage, it was down to 22v.
                              I quickly removed everything...
                              06-15-2024, 02:10 PM
                            • howardc64
                              Where do repair shops buy MB replacement batteries?
                              by howardc64
                              Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                              Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                              BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                              07-25-2024, 10:42 AM
                            • Astonished
                              Fixing the Charge Circuit of the Batteries of the DC Motor
                              by Astonished
                              Hi friends of electronics
                              What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                              The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                              Please help me fix this circuit.
                              (the datasheet of the IC: https://pdf.datasheet.live/28...
                              01-28-2025, 06:24 AM
                            • howardc64
                              UN55KU6270FXZA Backlight Flashing Briefly on Power On
                              by howardc64
                              Probably LED string issue but wanted to check any more easy testing before ordering the LED strips.
                              Inspection/Probing
                              • No shorts around caps on main
                              • No bulging caps on PSU, no evidence of any damage
                              Disconnected PWM_BLU between main and PSU
                              • Backlight powers on when PSU gets power. Doesn't wait for main board power on.
                              • Remote turn on TV, display is perfect. White screen test shows no dark spots
                              • Remote turn off TV, backlight stays on until PSU power pulled
                              • Both LED strings reads 124+V. 14x 3v LED / strip x 3 strips for each string
                              • PWM_BLU
                              01-21-2023, 06:06 PM
