TNPA5105 SC Repair KITS.
  • tw2005
    • Oct 2011
    • 6458
    Thought I'd throw this up in case anyone gets interested at self repair.
    Just some kits getting around of varying degrees of completeness.
    Only one you can see is OEM supplied components 10pce kit, 13pce kit interesting the extra 3 parts adds 100GBP?, nice copycat ad as well and another larger 17pce kit.
    10pce
    http://www.ebay.co.uk/itm/PANASONIC-...item25757b42b3
    looking familiar
    http://www.ebay.co.uk/itm/PANASONIC-...item1e8565bba6
    13pce, the price is absurd. States OEM, photo and description mismatch? Then in the body of the listing it says for repair of your board "the cost for this service is £89 for parts and labour"
    Easy, have them repair it and save 40-50GBP! Something's wrong there?
    http://www.ebay.com.au/itm/13pcs-REP...item3f2e5f7a0a
    This one is more complete, 17pce
    http://www.ebay.co.uk/itm/TCP50S2-TX...item2ecd791aa2
    Some info but anyone fixing could use most of the TNPA5081 items listed as a good guide to what can fail.
    Q621 ? will be something in spec close to a 30F125
    Q401 DG502LW
    Q402 DG502LW
    Q660 R5007ANX
    Q661 RJP63F4A
    Q451 45G128
    Q421 RJP43F4A
    Q422 RJP43F4A
    D482 RFUS20 TM4S? 430V 20A
    R551 10ohm 1/4W metalfilm 5%
    R506 10ohm 1/4W metalfilm 5%
    R451 5.6ohm 1/3W metalfilm 5%
    IC16521 M81737FP FET driver
    The TNPA5105 is a cut down version of the 5081 which I repaired.
    Not all of the transistors are identical but will be similar in rating, you'd have to compare the OEM numbers to figure it out more.
    The big list I created for the 5081. Unlikely you'll find this much blown.
    D16451 B0ECKP000055 DIODE 1 ROHM , RF101L4S 400V 1A
    D16482 B0FACP000003 DIODE 1 RFN25TM4SW
    Q16452 B1JAEP000012 TRANSISTOR 1 GT45G128
    D16702 B0ACCJ000048 DIODE 1 MA2J11100L 80v 100ma switching diode?
    IC16521 C0ZBZ0001708 IC 1 M81737FP
    IC16561 C0JBAU000088 IC 1 PAVCTH c541 buffer ic
    IC16562 C0JBAU000088 IC 1 PAVCTH c541 buffer ic
    IC16563 C0JBAB000916 IC 1 c14 INVERTER
    IC16691 C0JBAC000363 IC 1 TC7SH00FU(TE85L,J
    IC16724 C0CBADE00049 IC 1 BA178M05FP-E2
    IC16771 C0CBADC00072 IC 1 78L05L, TA78L05F
    IC16773 C0JBAB000715 IC 1 Toshiba TC7SH14F,
    PC16461 B3PBE0000054 IC 1 PS9856-2-F3-AX
    Q16402 DG3D5020CSLW TRANSISTOR 1 DG3D5020
    Q16403 DG3D5020CSLW TRANSISTOR 1 DG3D5020
    Q16421 DG3D4020CSRP TRANSISTOR 1 DG3D4020
    Q16422 DG3D4020CSRP TRANSISTOR 1 DG3D4020
    Q16521 B1HFPFA00001 TRANSISTOR 1 CPH5524-TL-E
    Q16551 B1HFPFA00001 TRANSISTOR 1 CPH5524-TL-E
    Q16621 B1JADN000009 TRANSISTOR 1 GT30F125
    Q16622 B1JADN000009 TRANSISTOR 1 GT30F125
    Q16647 B1CBGD000001 FET 1 2SK3018T106,2n7002
    Q16661 B1JAER000010 TRANSISTOR 1 RJP63F3A
    Q16701 B1ADCN000007 TRANSISTOR 1 MMBTA92
    Q16702 B1ABCF000231 TRANSISTOR 1 2PD601ART,215, 2SD0601A0L
    Q16818 B1CBGD000001 FET 1 2SK3018T106,
    R16452 D0GF5R6JA047 M 5.6 OHM,J, 1/3W
    R16521 ERJ6GEYJ101V M 100 OHM,J,1/8W 1
    R16522 ERJ6GEYJ101V M 100 OHM,J,1/8W 1
    R16551 D0GD100JA059 M 10 OHM,J,1/4W 1
    R16707 ERJ6GEYG392 M 3.9KOHM,J,1/8W 1
  • tw2005
    • Oct 2011
    • 6458
    Re: TNPA5105 SC Repair KITS.
    Reported successful repair on TNPA5105 for a 54", D451,RF101L4S 400V 1A had to be replaced also, first test failed.
    Repaired,working
    • RayOMG
      • Apr 2013
      • 6
      • Austtralia
      Hi tw 2005
      I have been looking throughthe threads on TNPA5081, since the board is no longer available in Oz through Panasonic.
      Generaly I shy away from repairs where parts have blown on a board all over the place instead of just one bank of transistors, have to admire your persistance on these boards.
      Unfortunatly I have to now try to fix one or two of the SC boards. where is the best place of getting all the parts in one hit, or is it better to just get a kit, some seem to have most of the stuff required, driver ICs smd resistors , FETS etc from UK.
      • tw2005
        • Oct 2011
        • 6458
        UTSOURCE is where I go for all the bits. Maybe got some resistors from RS and a TI sub for the toshiba schmitt inverter there too.
        To be honest some of the IGBTs seemed recycled but I did not care because what I got and used worked.
        ALIEXPRESS I read of someone using that but not real sure otherwise. OF course you could getthem from Panasonic which would make it very expensive and would put the pressure on to get it correct or $$$ up in smoke.
        kits are marked up a bit but the GTV watford ones have oem new components. I would expect that to be the most complete kit. The shopjimmy ones unless they have corrected a deficiency in those are a good price but postage is not great.
        Don't fall into the trap of trusting the kit will 100% repair the board. I know of someone who tried the SJ kit and they all blew again because there were a couple of key components not included which I would expect to see.
        • RayOMG
          • Apr 2013
          • 6
          • Austtralia
          Thanks tw2005, I did end up ordering from utsource, getting enough parts to do a few boards, they have everything except one transistor so lets see. Would be good to find out why all the parts blow in the first place, Panasonic would know and should put out a rebuild advice if they are unwilling to supply complete boards now for some times only 3 year old TVs.
          • tw2005
            • Oct 2011
            • 6458
            Which transistor?
            I wonder where the law stands? 3 years is still too young for the money they cost in 2010.
            Is it a 5105 or 5081 you're doing?
            • RayOMG
              • Apr 2013
              • 6
              • Austtralia
              couldnt get the Q16702 transistors, anyway all the other parts arrived and I have found more dead stuff. Im rebuilding 2 boards at onece TNPA5081 for a 50"
              and one for 54" set which I had lying around after replace ment. Seriously should have written the last set off though,
              • RayOMG
                • Apr 2013
                • 6
                • Austtralia
                Found a faulty SC board in my pile of dead parts out of an THP50G10, this has many sections and even the location numbers the same, and am currently canabalising this for the remaining parts. See how this ends up soon.
                • tw2005
                  • Oct 2011
                  • 6458
                  If you're doing a 5081, do me a favour and put the results in the 5081 thread.
                  A list of what IGBTs you found shorted?
                  As for Q702 2PD601ART, I had no trouble, just placed an order and it's on it's way. But it's just a GP NPN transistor so not too hard to sub for it.
                  I used BC846 only because jaycar was handy.
                  • tw2005
                    • Oct 2011
                    • 6458
                    These boards are scarce too, only way to get one in most cases is to find a component repairer.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Anyone have the schematic I cant find it on google ??
                      My board is a bit more complex, following parts some are not included in repair kits are dead:
                      Q451
                      D482
                      Q422
                      Q421
                      D402
                      D401
                      Q402
                      Q401
                      D422
                      Q660
                      Q661
                      IC521
                      R421
                      R422
                      R551
                      R506
                      If any one has the PN or schematic to help me find what parts I need I will be very grateful.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Started separate thread, please reply on there.
                        • magneh
                          Behringer Eurolive B205D repair - help identifying transistor
                          by magneh
                          Hello
                          Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                          Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                          After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                          I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                          Still, I need to replace this transistor....
                          06-18-2025, 02:34 AM
                        • elsomer
                          help to identify transistor msi ms-15ck1
                          by elsomer
                          hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                          02-17-2025, 05:30 PM
                        • rddube
                          Help with blowing transistor NAD T752 receiver
                          by rddube
                          I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
                          Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
                          I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
                          09-01-2022, 05:19 AM
                        • amigo744
                          xbox series x u82 5 pin transistor voltages ?
                          by amigo744
                          hello there,
                          xbox series x hdmi u82 transistor 5 pin,
                          can anybody tell me voltages of this transistor in standby and power on mode ???
                          on which pin of this transistor are the voltages ?
                          regards
                          08-16-2023, 08:05 AM
                          AO4601 AO4601L Transistor (Applications Laptops) Datasheet
                          Complementary Enhancement Mode Field Effect Transistor
                          The AO4601 and AO4601L use advanced trench technology MOSFETs to provide excellent RDS(ON) and low gate charge. The complementary MOSFETs may be used to form a level shifted high side switch, and for a host of other applications. Standard Product AO4601 is Pb-free (meets ROHS & Sony 259 specifications). AO4601L is a Green Product ordering option. AO4601 and AO4601L...
                          11-05-2024, 08:21 AM
