Samsung le37c530f1w
  • sordids999
    • May 2013
    • 2155
    Samsung le37c530f1w
    hi guys
    this tv keeps not switching on then its fine,the voltages seem fine but one thing ive noticed is that at the top of the invertor board i can hear a buzzing sound so im wondering if its the panel that is at fault ?
    thanks
    Re: Samsung le37c530f1w
    Not switching on? Symptoms?
    No power light ?
    No backlight, no sound ?
    Backlight, no pic, no sound ?
    Backlight, no pic, sound ?
    Checked any voltages...?
    BN44-###### number from power board and pin voltage diagram can be located
    Cold joints are a common issue. Also can be bad startup cap.
    Many inverters do buzz in operation, but if there is a bad smell or the buzz seems intermittent, like electrical arcing, it could be the lamp wire in the screen arcing. Fixable, but you need to take panel to bits.
      NVM here is power board saw your pic.
      • truep
        • Aug 2010
        • 373
        A buzzing sound at the top of the inverter? Is it coming from the transformer or one of the caps in the area? Doesn't sound like a bad panel.
        • sordids999
          • May 2013
          • 2155
          right symptons it will go into standby occasionally after using the tv and sometimes take a few attempts to turn it on after unplugging it a few times
          im testing for cold solder joints now and checking if any caps are faulty
            So when faulty, power light is LIT? Does main board respond to remote, e.g. with blinking light when you press a button?
            • sordids999
              • May 2013
              • 2155
              ok just had the fault the tv basically goes into standby then turns back on,and yes the main board responds with remote
                OK, start by heating parts of the power board & see if you can make it go wrong. Check power supply voltages and for any cold joints or obviously bad capacitors.
                • yousef yasser
                  • Jul 2015
                  • palestine
                  Hi every body
                  could you plz help me to know what was the problem of this issue !?
                  is it from backlight inverter or power supply board ?? cause i have the same problem
                  thnx alot
                  BR YOUSEF
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Lee never updated it lol I will Pm him see if he will update
                    • sordids999
                      • May 2013
                      • 2155
                      Opps sorry main board replaced all working again
                      • yousef yasser
                        • Jul 2015
                        • palestine
                        you mean the problem is from the main board ?!!!!
                        • telesantana2016
                          • Aug 2016
                          • turkey
                          ı have samsung le37c530f1w lcd tv.power board is not run.smallest power is not run.there is 3 power soirce.what is ohm this power.primer and secondary?
                          • telesantana2016
                            • Aug 2016
                            • turkey
                            anybodys knows not.
                              What is the P/N of your power supply board? BN44-?????
                                09-07-2024, 05:50 AM
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
                              • jchang
                                Samsung UN70NU6900F no picture and no sound
                                by jchang
                                Hi all
                                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                Symptom:
                                No picture no sound.
                                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                No sound at all.
                                What I tried:
                                1. I tried unplugging the left or right ribbon...
                                01-09-2023, 06:28 PM
                              • Ierwin
                                by Ierwin
                                05-13-2025, 03:31 PM
                              • ChaosLegionnaire
                                by ChaosLegionnaire
                                09-13-2022, 09:02 AM
