Panasonic TH-P50ST30A Not turning on, no error code!
  • Beavisjem
    • Jan 2014
    • 8
    Hi guys,
    I'll give a little back story for my problem.
    I have a Panasonic TH-P50ST30A that is 2 years old and after a big storm the other day (Brisbane, Australia) the Tv turned off. When I initially notice the TV wasn't working. (out in the garden sorting something out) The display was blank and the green light was on.
    I switched off the TV to avoid being damaged by the storm. After the storm passed I tried turning the Tv on and only heard the relays click but nothing on the Tv no picture, no blinks, no power light nothing.
    The Tv was plugged into a surge protector and so was everything else connected to the Tv. Surge protector has been tested and no surge was detected.
    It seems that the cable modem that was connected to the Tv via RJ45 cable was fried in the storm (classic burnt circuit board smell on the modem) The modem didn't get a direct strike but rather had a brownout moment in the storm and it fried.
    Anyway I think the Modem sent a voltage to the Tv via the RJ45 Cable (modem runs at 12v DC)
    Could this have broken the TV
    Diagnosis
    Decided to take the back off the TV and have a look, nothing obvious, no caps bulging, tested the power board and I am getting voltage, so I am assuming the power board is ok.
    It seems that the Main A board is not telling the TV to turn on due to it being defective. The fans don't come on and neither do any picture/sound/power light
    Are there any other things I should test before I look at the possibility of a replacement A board?
    I am also having issues finding the correct board, I have the service manual for the TV and I have put the board number in several places and not been able to find the correct parts.
    Any help would be much appreciated. If you need anymore information please let me know
    Cheers
    Chris
    Re: Panasonic TH-P50ST30A Not turning on, no error code!
    Try unplugging SN and SS -- if error code changes, typically to 6,7,8 blink you may have a shorted SS/SN board
    • tw2005
      • Oct 2011
      • 6458
      Just in case it's not storm related, disconnect SC2 (Vsus from the SC board) and try powering on. SC boards short out , There's a 2011 guide with some flowcharts getting around this forum if you search the US equivalent models.
      I'll have a dig later, after dinner.
      • Beavisjem
        • Jan 2014
        • 8
        I just pulled the back off and tried what you said.
        I disconnected the SC and via power and ribbon cable and no change. Just the usual relays clicking.
        Just so I know what I should disconnect and which board I am messing with, here is a picture from Panasonic of the back of my TV with the boards labeled that I am using.
        I don't see an SC2 board? But I tried what you said with the SC
        Thanks for the help so far
        Chris
        • tw2005
          • Oct 2011
          • 6458
          Probably worth mentioning this too. I think revised consumer laws came into effect for out of warranty claims. These have a fairly widespread issue with the SC so you may try Panasonic for the repair based on the new law which you'll have to check out for yourself.
          Once you open it up this is probably voided but if you can do it without any evidence of tampering like burring the heads of the screws you may get away with it.
          http://www.abc.net.au/news/2011-06-0...rights/2749924
          i don't know if it was 2011 or 2012 that it was revised but may be worth investigating.
          Either way with a brand like panasonic and the price of these, I'd try it.
          • Beavisjem
            • Jan 2014
            • 8
            Hi Tom,
            Which one would be the SN board?
            Cheers
            Chris
            • tw2005
              • Oct 2011
              • 6458
              What Tom and I are suggesting is Vsus could be dead short on either the SC or SS. I was quoting the connector on the Sc, SC2 with the brown and white leads from the PSU. can be 200V there and there will be residual voltage there after a power cycle so avoid reconnecting straight away.
                On this, SN = SC.
                • tw2005
                  • Oct 2011
                  • 6458
                  There's no SN in this size, 42 has a SN which is combined SC,SD,SU on a single board.
                  • Beavisjem
                    • Jan 2014
                    • 8
                    Just disconnect the power to the boards? Or the power and the ribbon?
                    Chris
                    • Beavisjem
                      • Jan 2014
                      • 8
                      Hmm I had it open several times, so chances are slim. Not that the screws are burred but they show signs of being undone.
                      Thanks for the advice anyways
                      Chris
                      • Beavisjem
                        • Jan 2014
                        • 8
                        Right just tried disconnecting the power from both the SC and SS, plugged it in and turned it on and the same result.
                        No lights, nothing, just the usual relay click.
                        Chris
                        • tw2005
                          • Oct 2011
                          • 6458
                          I don't have much more for you , could be A board.
                          For US market, see if page 33 makes any sense for your model.
                          • Beavisjem
                            • Jan 2014
                            • 8
                            I'll check the problem solver on page 33 from the manual you provided tomorrow.
                            Just looking into the future, any idea where the best place to source a replacement A board?
                            Cheers
                            Chris
                            • tw2005
                              • Oct 2011
                              • 6458
                              Cheers
                              Chris
                              Can you work out the board number and revision? Should be a TNPH number or actually there may be a white sticker on it. Could be TXN/A etc.
                              That doc you grabbed from Tom, does that have your exact model in it with the board numbers?
                              Prime electronics Bowen Hills, i ordered an OEM EEPROM for an A board from them. I think Jenny? They know their stuff. Hopefully they'll help out but $$ could be expensive.
                              Contents insurance for lightning/power surge? I could have claimed for a hit in Darwin but the Suncorp excess made it pointless especially for myself when I can do a fair amount of self repair and I've built up a little stock pile of boards for my 2010 model so I rather keep it. getting a newer and even less reliable panasonic plasma was not attractive for me.
                              By the way I'm not a professional TV repairer, had some fun with a few sets though.
                              • tw2005
                                • Oct 2011
                                • 6458
                                I found the same doc in Toms library and your model is showing in that so the A cold be tztnp01naua which a google brings nothing up.
                                The PCB should also have a TNPHxxxx and a 2 letter suffix stamped on it somewhere. I think if ordering though the TZTNP01NAUA will be what Prime will need. But they should work it out with the model number too.
                                You'd have to confirm it. You may get lucky and one of these TVs may pop up on Ebay but nothing I can see now.
                                • BigPete
                                  Panasonic Heatpump Dryer Repair
                                  by BigPete
                                  I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                  The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                  In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                  Unfortunately the whole machine has to come apart to fix it.
                                  I have...
                                  11-01-2025, 06:40 PM
                                • Amraks
                                  Panasonic SA-MAX770 (not turning on)
                                  by Amraks
                                  Hey all its been awhile since I have needed to post here.
                                  Panasonic - SA-MAX770: Symptoms not turning on
                                  Power Supply
                                  C1403 has 330v
                                  IC1402 Looks perfectly fine no blown out holes.
                                  C1601 has 3.3v
                                  CN1851 Has its 3.3v but no 15v all I am getting is on the 14v rail is 0.400v
                                  Not sure where I should be looking next for this any help would be appreciated...
                                  10-04-2022, 12:12 AM
                                • Andre Gilbert
                                  by Andre Gilbert
                                  11-20-2024, 08:52 PM
                                • AquaMan Ua
                                  Problem with PANASONIC CF53 laptop after changing BIOS settings
                                  by AquaMan Ua
                                  Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                  05-17-2025, 09:40 AM
                                • stecos
                                  Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                  by stecos
                                  Hi everyone!
                                  I happened several times, in the search for help from the web, to consult this very interesting forum.
                                  So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                  Having said that I come to the gist of my post on the forum as the title suggests.
                                  For my passion for technology I'm now collecting several...
                                  11-28-2022, 11:39 AM
