Sony Bravia KDL-46XBR4 T-Con Compatability
  • littlebird
    • Mar 2014
    • usa
    Re: Sony Bravia KDL-46XBR4 T-Con Compatability
    Hi Tony,
    I need the same type t-con 404652HHC8LC1.8 LJ94-01954F for my KDL-46XBR5 TV.
    Did you try the Samsung LJ94-01953H T-Con Board whcih Jimmy shop recommend?
    Jeff
    • bevwa
      • Mar 2016
      I have the same problem and are after a 404652HHC8LV1.8 board. TV comes on sometimes if i keep changing/holding down the channel button while on or it will turn off after about 30 secs. Once finally pic appears it will stay on and act normally. Have seen status report and it indicates Tcon board however ive seen two versions of the board on various sites.
      Bevan
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
      • JUCaESAl
        Sony bravia KD-65AF9
        by JUCaESAl
        Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
        Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
        10-20-2025, 04:03 AM
      • swrb898
        Sony KD-70X690E Bravia; Bad TCON? Bad panel?
        by swrb898
        What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
        Problem:
        Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
        My troubleshooting got me this far:
        With the left-hand TCON to bottom-board ribbon cable...
        12-28-2021, 08:12 PM
      • iglitare
        Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
        by iglitare
        i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
        Backlight seems to work, Sound (Setup menu after reset) works.
        If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
        Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
        With my small knowledge i would think at least the cables are good.
        Can this happen because of a bad tcon board?
        Or is it always a bad/shorted...
        09-04-2025, 07:13 AM
      • PopsCaps
        Sony Bravia KDL-40V2500 that will not power on
        by PopsCaps
        I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
        I do not hear any sound and I cannot see any backlight.
        I have tried disconnecting every cable on each board one at a time to see if anything changes.
        The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
        My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
        03-25-2025, 11:23 AM
