Phillips 52PFL5704D/F7 main board
    Re: Phillips 52PFL5704D/F7 main board
    There are tiny tiny pins come out at the bottom of the white plastic, the pins are surface mounted and you can see that they are connected to some of the copper traces with vias on them, the vias do not have solder mask on the them so you will not get good electrical contact to take the readings.
    But let's says that we see big different in the voltage readings, the question will be how to figure out which component is bad, I think the bad part is the IC on the right side of the board.
    • whatusername
      • Dec 2013
      • 456
      go back to post 29 max zoom on the pic and look at the corner of the ic where it reads 128 and tell me if u see what i see
      • whatusername
        • Dec 2013
        • 456
        i will test the vias pins now
          It has blackened look to it, not sure if something burn up at that corner or not.
          • whatusername
            • Dec 2013
            • 456
            yea it does and those pins are too tiny and hard to test but the first few were 5.3v 0v 31.4v 0v 1.9v 0v then i couldnt test anymore
            • whatusername
              • Dec 2013
              • 456
              ok bud im using my microscope and dvom at the same time here is a pic of the right side and will post voltages as i find em
              ok i got 9 pins in this pic. there are lots more but i got to do it little by little this is going from right to left when i post them and it is the end of the right connector that will be pin 1
              i think these are gamma curve voltages but here are the first 9 from RIGHT to left meaning the first right pin = 0v and so on and so on
              0v 1.3v 3.4v 3.9v 4.3v 4.7v 5.1v 5.6v 7.3v
                The connector are mirror image. It looks a lot of connections from the connector go back to the black IC.
                • whatusername
                  • Dec 2013
                  • 456
                  yes it would seem that way.. do u still want me to continue measuring the voltages?
                  btw read post 46
                  • whatusername
                    • Dec 2013
                    • 456
                    the next 9 they have what looks to be either a resistor inline or a fuse its a fuse same voltages both sides
                    10-18
                    15.5v 15.5v 3.2v 3.2v 1.2v 1.0v 0.4v 0.3v 1.1v
                      They may be resistor network.
                      • whatusername
                        • Dec 2013
                        • 456
                        ok well this is a pain to do and im sleepy its 130 am here i will continue this tomorrow when i wake up since i am off
                        ok well maybe not tomorrow i just saw i got the parts from the other 3 tv's u been helping me with coming in tomorrow morning so i will do them first.. the tcon board for the toshiba the voltage regulators for the proscan and the repair smd kit for the sanyo
                        then if time permits i will get back on this one.. GN bud thanks for all ur help
                          OK, let me know if the parts will fixed the other TVs, I cannot keep track of all the TVs I have been helping you with.
                          • Steamy777
                            • Oct 2013
                            • 8
                            Hi i have a problem with my phillips i thing t con
                            One the picture is great
                            The second one the yellow has lines in it only yellow and green make the lines in it could it be the t con board or panel
                            • Dani_2024
                              by Dani_2024
                              10-28-2024, 05:06 PM
                            • ygorsan
                              by ygorsan
                              🧩 Problem Summary:
                              • I
                              07-28-2025, 08:34 AM
                            • jb_Bak
                              by jb_Bak
                              CN6401
                              Pin 01 NC
                              Pin 02 NC
                              Pin 03 "BL_ON": 0V
                              Pin 04 "N/C"
                              Pin 05 "STBY 3.3V": 3.5V
                              Pin 06 "GND": N/C
                              Pin 07 "AC_OFF"...
                              09-27-2021, 04:52 PM
                            • JDC
                              (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                              by JDC
                              ONN 100012588
                              Issue: No Power, Then Rebooting After Main Board Change
                              Short answer: replace main board and power board
                              Technical answer: replace main board and Q306 & Q307 on power board.
                              Long answer:
                              TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                              07-15-2022, 07:39 AM
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
