Toshiba Regza 32AV615DB Flashing Screen sort of
  • aar5384
    • Jan 2014
    • 82
    • England
    Re: Toshiba Regza 32AV615DB Flashing Screen sort of
    Originally posted by tom66
    sounds like tab bonds - bane of LG panels as it's -usually- not fixable unfortunately, my luck has been poor with them 0 out of 3 LG panels with tabs fault repaired successfully.
    The tabs ive already decided to clamp if i get any moreflikering but the lightening and dimming?
      could be main board try flicking between picture modes and turning all dynamic contrast etc off. Does it appear in menus. Whole screen or just part?
      • aar5384
        • Jan 2014
        • 82
        • England
        tried menu settings, and yep its in menus, thats how i saw it with the torch
        • aar5384
          • Jan 2014
          • 82
          • England
          Well i had a go at the plastic ribbon connectors that look like selotape coming from the thin lcd panel to the strip of circuit board on top of the lcd casing. I used some tin foil wraped around the end of soldering irn and applied heat to the contact part of the plastic with it touches the millions of thin metal contacts, it stuck it back down well
          Until i forgot to support the lcd panel and it fell out of the case and pulled the plastic strips connectors from the actual panel! Damit! they looked like the were stuck on with a very thin strip of silicone of some sort
          Ahwell, while i was doing it aswell, the flashing screen had stopped happening until it fell
          That meens i have all the internals working apart from the screen ! Anyone need anything ? lol
          Thanks again
          • samcoaker
            • Jan 2015
            Sorry to bump an old thread, but im a newbie here.
            I have this model tv which i have been given, with a black screen and multi coloured lines. I have no knowledge regarding tv's but am handy with tools. I understand they consist of an lcd panel, and various circuit boards, but woth my lack of knowledge ab unable to diagnose the fault.
            It doesnt have any visible lcd damage, which makes me question its possibly a board fault? Any help would be much appreciated
            • HTR-Informatique
              Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
              by HTR-Informatique
              YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
              I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
              On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
              I also changed the screen because the PC fell and the screen was broken.
              I changed the battery with a new and original battery.
              I also had corrosion/oxidation on the...
              02-09-2025, 06:51 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
            • dbuergi
              Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
              by dbuergi
              i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
              Any ideas where to look?...
              11-07-2024, 10:57 AM
            • Chrissygizmo
              by Chrissygizmo
              02-10-2025, 12:33 AM
