Hi everyone I have this Samsung un75nu8000 I need some direction on removing the screen. I’m not sure exactly how it comes out. It looks like it’s part of the frame and I cannot find anything regarding this particular TV. Any help will be greatly appreciate it. I need to replace the LED lights, .
Samsung un75nu8000 removing screen
Yes likely it's part of the outer plastic bezel. The outside plastic frame should snap off and stay connected to the tv. I would start on a left or right edge and put palms lightly on screen and pull bezel outward and up and should pop off as you go around the tv. I believe the bottom strip of the TV comes off and is to the screen, that's my experience. It would be foolish to try and pull the screen off (after popping the edge bezels) without 2 sets of double suction cups. Pictures would help though so we can confirm. -
put the set screen downside on your table after use blanket to set it on.... free all speaker edge boards metaöö cover and led front indicatore...
remove the bezel by release the clips which it hold it on tv chassis..
the bezel we will be free .. flip the tv so screen on the top ... remove totally the bezel... use solid thin card to check if the LCD sitting on double side glue band,, the case cleared use the double suck cups to release it up... be careful of the cups position that no way the LCD wave up at pulling out.Last edited by Diah; 01-15-2024, 12:51 PM.Comment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by ChrissygizmoHello everyone, I’ve just been given a Samsung UE55JU6800K smart tv as it had white spots on the screen due to the led lenses falling off. After refitting them & putting the tv back together I thought it was a nice easy fix for a free bedroom tv , then I tried it before screwing the back into place. I realised that the right side of the screen was darker than the other side, I removed the screen again as I thought the backlights had failed but they are fine.
I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same... -
by ChrissygizmoHi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
Ive eventually managed to get it on and working but it's very temperamental...
The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...05-26-2024, 12:05 AM -
by JunkmanJimboSamsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
Please help. Thanks in advance! - Loading...
