panasonic TH42P285B
  • vinceroger69
    • Mar 2012
    • 6714
    panasonic TH42P285B
    Panasonic TH 42P 285B another free cycle project just been dropped of to me has the 10 blink code any help appreciated.
    a little up date once in say 20 times it powers on OK picture has a blue very faint dotted line dead center top to bottom only really visible on black scenes any ideas and is behind the osd box.
    Re: panasonic TH42P285B
    Blue dotted line looks like panel fault to me, unfortunately. 10 blinks is an easy fix and well documented. http://www.youtube.com/watch?v=LjpGKaBt8hg
    • vinceroger69
      • Mar 2012
      • 6714
      its weird tom the dots are behind the osd box not in front only visible really black scenes.
        Blue dots don't appear over white. If you try grey you'll probably see some.
        If you can live with that minor fault you've got a VERY nice TV, I personally have 46PZ80 and 42PZ80 and love both.
        • vinceroger69
          • Mar 2012
          • 6714
          cheers tom i have ordered Panasonic m series thats all cpc had does the video show the polarity on the caps? would altering the voltages alter the blue line its visable too me but not to others lol dead center of screen looks a good set got to pick up the power lead and remote control from the people tmoz they actually dropped the set of to me not bad for a freebie thats 3 sets last week from 1 wanted add and a hdmi dvd recorder pity only analogue tuner though.
          tom have you got the correct manual for this set?
            For US version yes
            I doubt adjusting voltages will do anything.
            • vinceroger69
              • Mar 2012
              • 6714
              is it worth checking the voltages then as per panel sticker and adjusting if needed or leave alone? fans need a clean etc anyway and may check for other bad caps whilst in there so just needed manual to see test points etc.
                Vda is only voltage that might affect this and is fixed at 75V. Vsus and Ve do not effect it.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  cool thanks will see how bad it is once replaced the caps. looks a nice set the time the picture was on i will keep this set myself i actually i don't sell any sets i get i just give to family/good friends they just give me the money for parts/remotes etc i just do this as a hobby and to learn etc.
                  tom slightly of topic which air duster do you use as freeze spray i have tried the pound shop laser brand does not seem to work to much fluid when upside down no white frost etc? any particular brand you have found thats good?
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Looks like panel fault. I believe c boards present a high to the SS board and faults out on this condition. I may be wrong, but could be it.. Always present due to a defective driver IC, but may sometimes just not be enough voltage on the error circuit to allow the set to pass the error cycle check.
                      10 blinks is 99% PSU due to MC201/MC301 faults.
                      I have found the Poundland LAZER stuff to work fine, they don't have very much liquid in them, so use sparingly. Not as good as real freeze spray, of course, but that stuff costs an absolute fortune.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        some pics of how bad the dust was inside ive never had on this bad
                          Oh dear wow, that is by far the worst right there. Never seen it that bad before.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            tom any way i think your having a laugh about soldering them capacitors on they are soooooooooooooooooo small hahaha but i will try a good light and borrow a good magnifying glass on a stand might help tom i have ordered normal caps as you suggested can i fix it on to the ic with a bit of hot melt glue? does the ic get hot.
                            2008 on the panel sticker so not that old at all.
                              all PZ80s are 2008.
                              TH..PV/PX50 = 2005
                              TH..PX60 = 2006
                              TH..PX/PZ70 = 2007
                              TH..PX/PZ80 = 2008
                              TC..10 = 2009
                              TC..2/25 = 2010
                              TC..3/30 = 2011
                              TC..50 = 2012
                              TC..60 = 2013
                              (the 60 series is Panasonic's last!)
                              The IC runs cool. But hot melt glue is too brittle for a warm power supply, I would use general adhesive instead.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                Re: panasonic TH42PZ85B
                                will do then tom they do look well built sets imo. no wonder i could not find a review about them i put th42p285b not TH42PZ5B hahaha.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  hi guys just to update this thread the job was a bit tricky some disassembly required to remove the whole psu and then the 2 boards to replace the two small capacitors i used ordinary leaded ones glued onto the ics and im glad to say the sets working great and the line in the center of the screen now seems to of gone for now. i cant see it all all so now i have a great looking 42in plasma in my lounge for the cost of two capacitors and my time as the set was free cheers tom for your advice as usual.
                                    Nice fix... Have started trying freecycle etc and got a few interesting hits. Can't complain if they're free.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      no this plasma was totally free even delivered to me they had forgotten the power lead and the remote but i collected them from the people its a great picture on these sets imo the black colors even look nice will keep this set myself not going anywhere haha.i have just placed another wanted add on my freecycle for any faulty electronics has to be done need to keep busy haha.
                                        It's plausible that blue dotted line is a loose LVDS cable, I'd keep it only together with 4 screws for a few days to make sure it doesn't come back.
                                        Yeah now you have me jealous, 42" PZ85 is top of the line model, does it have Freesat HD? Can't remember - my friend has PZ81 and that does.
                                        • BigPete
                                          Panasonic Heatpump Dryer Repair
                                          by BigPete
                                          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                          Unfortunately the whole machine has to come apart to fix it.
                                          I have...
                                          11-01-2025, 06:40 PM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • fredtred
                                          Physically bending the T-Con board creates horizontal dotted lines on OLED55CXPUA
                                          by fredtred
                                          Hello!
                                          I have been trying to solve this issue the past 12 months to no avail. I have been a lurker here during that time but finally decided to post my problem and see if anybody knows a solution.
                                          Problem
                                          My tv (OLED55CXPUA) has an issue where it displays horizonal lines of dotted artifacts.
                                          (See Attachment 1)
                                          Self Diagnosing
                                          After a very long troubleshooting period I traced the issue to the T-Con board. If I gently flexed/bend the board I could make the display go from GOOD to BAD and vice versa. I have ruled out the connectors/wires...
                                          10-29-2023, 01:09 PM
