Samsung PS50A557S3F - vertical lines on right hand side
  • noledud
    • Dec 2013
    • 413
    • united kingdom
    Re: Samsung PS50A557S3F - vertical lines on right hand side
    any particular board i need to look at as i double checked they were all ok befor powering back on
      C-board -- one that runs along the bottom of plasma panel.
      • noledud
        • Dec 2013
        • 413
        • united kingdom
        the connectors on the buffer boards can i leave one off to see which effects the line ?
        • noledud
          • Dec 2013
          • 413
          • united kingdom
          thanks will check the c board
            Yes but absolutely do not ever reconnect it with power on.
            • noledud
              • Dec 2013
              • 413
              • united kingdom
              #26
              i wont thanks mate will report back
              • noledud
                • Dec 2013
                • 413
                • united kingdom
                #27
                its still there not sure what more i can do
                  Any corrosion on the connectors from control to C-buffer boards?
                  • noledud
                    • Dec 2013
                    • 413
                    • united kingdom
                    #29
                    i presume c buffers are the bottom ones - no
                      Reseated the connector for that driver chip? Pictures of the C board and the connector can be highlighted, if you are having trouble.
                      • noledud
                        • Dec 2013
                        • 413
                        • united kingdom
                        #31
                        can you please so i know where you mean ?
                          I need a picture first...?
                          • noledud
                            • Dec 2013
                            • 413
                            • united kingdom
                            #33
                            sorry was getting it
                            the last pic is where the prob is on the screen each brown connector has 2 ics so its one of the middle 2
                            but i did re seat all the connectors to the y buffer also not sure if that changed it
                              Those connectors are bonded to the plasma panel. I thought they were on connectors. Didn't know Samsung did that for A-series 1080p.
                              https://www.badcaps.net/forum/attach...4&d=1388863300
                              Try the blue connector, if not I would have suggested C board replacement but that's a no go as it's bonded like an LCD.
                              • noledud
                                • Dec 2013
                                • 413
                                • united kingdom
                                #35
                                iv cleaned that a few times now, i will clean the whole board connector and control board as nothing to lose so close now its worse that being a dead panel lol
                                • noledud
                                  • Dec 2013
                                  • 413
                                  • united kingdom
                                  #36
                                  cleaned all again still no change
                                  do you think trying replacing the cable or the control board
                                  attached latest pics
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Oddly given the failure rate of Samsung C buffers, Im going to have to say that this may in fact be a ribbon connection issue, as it looks like the image in the bar is trying to mock the data coming into the IC, usually when the IC goes bad, there will be lines within the bar or no image at all. Or worse case scenario, all white.
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      Go over the white ribbon cable and all pins with a fine tooth comb. Look inside the clamp connection on both boards. Look for bent pins and or any other sign of fatigue. considering he brought back 90 percent of the screen by just messing around with the ribbon cablestells me that there's probably still at that connection somewhere especially given the fact that it's trying to mock an image inside the bar
                                      • noledud
                                        • Dec 2013
                                        • 413
                                        • united kingdom
                                        #39
                                        hi All
                                        SUCCESS !!
                                        Git rid of the lines after taking apart many times and cleaning
                                        however it now seems to burn the screen very quickly
                                        Ie if i turn the volume up and the boxes comes up for like 30's when you then change the screen you can still see the box
                                        also has a redish tint around the edges
                                        it does fade (the box not red tingh) but it seems as if the screen isnt wiping clear as quick as it should
                                        now i want ask is this age but i cant say i have seen this before ?
                                        its going to be very hard to get a picture of it, i hope someone knows what i mean and have seen this before
                                        Has it got anything to do with the fact its a 2nd hand PS ?
                                        • noledud
                                          • Dec 2013
                                          • 413
                                          • united kingdom
                                          #40
                                          here are the pics
                                          • Stanley1843
                                            by Stanley1843
                                            06-29-2024, 11:54 AM
                                          • x_orange90_x
                                            Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                            by x_orange90_x
                                            I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                            The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                            09-04-2023, 12:09 PM
                                          • polaro
                                            Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                                            by polaro
                                            Greetings,
                                            I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                                            08-27-2022, 08:46 AM
                                            09-07-2024, 05:50 AM
                                          • Anonmis
                                            Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
                                            by Anonmis
                                            Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
                                            The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
                                            12-01-2023, 04:31 PM
