Samsung PS50A557S3F - vertical lines on right hand side
    Re: Samsung PS50A557S3F - vertical lines on right hand side
    any particular board i need to look at as i double checked they were all ok befor powering back on
      C-board -- one that runs along the bottom of plasma panel.
        the connectors on the buffer boards can i leave one off to see which effects the line ?
          thanks will check the c board
            Yes but absolutely do not ever reconnect it with power on.
              i wont thanks mate will report back
                its still there not sure what more i can do
                  Any corrosion on the connectors from control to C-buffer boards?
                    i presume c buffers are the bottom ones - no
                      Reseated the connector for that driver chip? Pictures of the C board and the connector can be highlighted, if you are having trouble.
                        can you please so i know where you mean ?
                          I need a picture first...?
                            sorry was getting it
                            the last pic is where the prob is on the screen each brown connector has 2 ics so its one of the middle 2
                            but i did re seat all the connectors to the y buffer also not sure if that changed it
                              Those connectors are bonded to the plasma panel. I thought they were on connectors. Didn't know Samsung did that for A-series 1080p.
                              https://www.badcaps.net/forum/attach...4&d=1388863300
                              Try the blue connector, if not I would have suggested C board replacement but that's a no go as it's bonded like an LCD.
                                iv cleaned that a few times now, i will clean the whole board connector and control board as nothing to lose so close now its worse that being a dead panel lol
                                  cleaned all again still no change
                                  do you think trying replacing the cable or the control board
                                  attached latest pics
                                    Oddly given the failure rate of Samsung C buffers, Im going to have to say that this may in fact be a ribbon connection issue, as it looks like the image in the bar is trying to mock the data coming into the IC, usually when the IC goes bad, there will be lines within the bar or no image at all. Or worse case scenario, all white.
                                      Go over the white ribbon cable and all pins with a fine tooth comb. Look inside the clamp connection on both boards. Look for bent pins and or any other sign of fatigue. considering he brought back 90 percent of the screen by just messing around with the ribbon cablestells me that there's probably still at that connection somewhere especially given the fact that it's trying to mock an image inside the bar
                                        hi All
                                        SUCCESS !!
                                        Git rid of the lines after taking apart many times and cleaning
                                        however it now seems to burn the screen very quickly
                                        Ie if i turn the volume up and the boxes comes up for like 30's when you then change the screen you can still see the box
                                        also has a redish tint around the edges
                                        it does fade (the box not red tingh) but it seems as if the screen isnt wiping clear as quick as it should
                                        now i want ask is this age but i cant say i have seen this before ?
                                        its going to be very hard to get a picture of it, i hope someone knows what i mean and have seen this before
                                        Has it got anything to do with the fact its a 2nd hand PS ?
                                          here are the pics
