SAMSUNG HG40ED450BW Striping Picture
  • Ukdigger
    • May 2020
    • 121
    • England
    MAIN BOARD BN41-02217B BN94-08383W
    POWER SUPPLY BOARD BN44-00754A
    Power board has steady 12.1v . TV works normally for about 30 mins, then has striping at the bottom of the screen. Heat sink on the mainboard feels hot. If I turn the TV off and back on again the striping is still there. If I wait until the heat sink is cold, the TV works normally again for about 30 mins.​ Any help would be welcome.
ID:	3161903 Click image for larger version
ID:	3161904 Click image for larger version
  • vinceroger69
    • Mar 2012
    • 6714
    panel tab bond issue?
    • trubec
      • May 2021
      • Česko
      It is problem with CLK data to panel, i have same issue, but i searching for scheme on bn94-16986R. Horizontal lines = CLK data problem. You can solved with tape on one of sides panel, you put tape on CLK pins or pin, but you need scheme like me or you can laborate and search with diod test on multimeter. PIN out on that flex cables what goes from Tcon desk to electronic on panel. It is full YT with manual how on that.
        • 12187
        • U.S.
        He doesn't have horizontal lines in the picture, for anyone wondering, _ is horizontal, | is vertical, so line going from top to bottom is vertical, line across the screen is horizontal, kind of surprising how many get that wrong or mixed up.
          • 12187
          • U.S.
          Post number 2 was probably referring to something like this and it may be your issue: https://www.youtube.com/watch?v=purk_SyiT44
          • Ukdigger
            • May 2020
            • 121
            • England
            Removing the left 2 cables cures the striping, pic 1. Pic 2 shows what happens when just the cable with the suspected fault is left unconnected, this also cures the striping. Am I right in thinking the tape method can be used to cure the fault. If so any ideas on which pins to block.
            • Ukdigger
              • May 2020
              • 121
              • England
              I must have just got lucky because the striping has gone. I must have disturbed something, It has been on for an hour without the fault. I will update if anything changes.
              • vinceroger69
                • Mar 2012
                • 6714
                Hopefully it was just a loose/dirty cable and re seating it has solved the issue all you can do now is keep it on test turning it on and off at time too hopefully the issue has now been resolved.
                  09-07-2024, 05:50 AM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • adam brown
                  Samsung qe55q7fam picture issue after a few mins
                  by adam brown
                  Hi my samsung tv comes on fine the after a minute or two the picture goes like attached any ideas?
                  06-24-2024, 03:21 PM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
