LG 39ln575s - power ON, backlight ON but no screen
  • bajdik
    • Aug 2015
    • 68
    • Czech Republic
    LG 39ln575s - power ON, backlight ON but no screen.
    I checked TCon board V390HJ1-CE1 and VCL -8V, VCH 30.2V.
    Display is HC390DUN. With both strip is backlight only - nothing on the screen.
    If I put 1st strip off, I see 50% black 50% white. If I put 2nd strip off, see some lines vertical/horizontal with pink color (probably color of LG logo) and after that, white on thle left corner.
    The IC chip CM501 (probably booster for VCL and VCH is hot - after 1 minute is not possible to put finger for more than half second.. So I think it has got about 70C. Is it normal?
    Has anyone voltage for test pins on the TCon board?
    Any idea? Thank you.
  • lotas
    • Jan 2016
    • 4830
    • Russia
    No, this is not normal, either there is a short circuit at the outputs of this chip, or the chip itself is not fixed.
    • bajdik
      • Aug 2015
      • 68
      • Czech Republic
      OK, I will buy a new T-Con board and try it.
      • HTR-Informatique
        Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
        by HTR-Informatique
        YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
        I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
        On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
        I also changed the screen because the PC fell and the screen was broken.
        I changed the battery with a new and original battery.
        I also had corrosion/oxidation on the...
        02-09-2025, 06:51 AM
      • frannyjunk
        Hisense 40H4F no backlight but turns off after splash screen
        by frannyjunk
        So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
        TIA.
        09-24-2025, 10:59 AM
      • turmix
        AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
        by turmix
        Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
        The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
        At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
        During another reassembly, I made a mistake, and...
        01-29-2024, 03:48 AM
      • FallenOne008
        Asus G712L No Screen Backlight
        by FallenOne008
        Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
        The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
        03-31-2025, 08:27 PM
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
