Sony KDL-50W685A horizontal black lines Pattern
  • Raulnn
    • Nov 2022
    • 103
    • España
    Originally posted by lotas
    Check the fuse on the t-con and see if there is any voltage on the t-con.
    I think the LVDS cable is fine. The tcon receives 12v from the fuse, even in the sub-sources there is voltage. I can see the 3.3v power supply from the dc dc converter
    • Diah
      • Feb 2013
      • 6424
      remove the bezel and inspect the screen side glass if there any damage
      • Raulnn
        • Nov 2022
        • 103
        • España
        Thanks! No. I have disassembled the frame and it is perfect. The problem is with the tcon, DC DC converter area, but I don't know how to test if the converter is okay. the converter gets hot, the 3.3v and 1.7v test points are fine.
        • Diah
          • Feb 2013
          • 6424
          show here photo of the circuit you mentioned and mark on it the part u said it get hot
          • Raulnn
            • Nov 2022
            • 103
            • España
            hello! In the photo there are several voltage reference points AVDD, VGL, VSS. these give incorrect values. however, the 1.2v and 3.3v benchmarks are correct. The supply voltage of that integrated is correct. I don't know if the problem is with that integrated part or with another component of that circuit.
            • Raulnn
              • Nov 2022
              • 103
              • España
              #26
              Can you help me? I don't know how to differentiate a problem in the DC DC converter, or in some nearby capacitor. the converter is very hot
              • Diah
                • Feb 2013
                • 6424
                this is non DC /DC... contact AUO in Taiwan and give them the last photo you uploaded--- they will send you free of charge 8 ribbon set of COF need to replace... but you need to have 6000 euro coast of COF install machine.
                • lotas
                  • Jan 2016
                  • 4708
                  • Russia
                  #28
                  Check the resistance of test points CKM1-CKM6 at the output of this chip relative to ground.
                  • Raulnn
                    • Nov 2022
                    • 103
                    • España
                    #29
                    Thanks. I have measured at the test point with a black ground terminal.
                    CKM1: 83,5 Kohms
                    CKM2: 1,8 Mohms
                    ​​​​​​​CKM3: 1,8 Mohms
                    ​​​​​​​CKM4: 1,6 Mohms
                    ​​​​​​​CKM5: 1,6 Mohms
                    ​​​​​​​​​​​​​​CKM6: 1,6 Mohms
                    • Raulnn
                      • Nov 2022
                      • 103
                      • España
                      #30
                      thank you. I hope you are wrong 😁😅😭
                      • Raulnn
                        • Nov 2022
                        • 103
                        • España
                        #31
                        riddle solved. A flex where the integrated hood is located is damaged. Someone did a bad job and ruined it.
                        • Diah
                          • Feb 2013
                          • 6424
                          thus you call it flex.... its the COF which Taiwan could send to you free of charge
                          • Raulnn
                            • Nov 2022
                            • 103
                            • España
                            #33
                            It's not the cof, look at the damage. but your hypothesis was the right one, because the fault is in the housing cof 😁
                            • Diah
                              • Feb 2013
                              • 6424
                              because of the COF overload can also burn the lines on flex
                              • noisykid
                                Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                by noisykid
                                5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                12-30-2024, 07:15 PM
                              • ggil44
                                Sony XBR-65X750D Horizontal lines bottom of screen
                                by ggil44
                                Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                                05-30-2023, 07:51 PM
                              • howardc64
                                by howardc64
                                07-24-2025, 05:17 PM
                              • dvu0627
                                Sony XBR65X900H TV with Horizontal Lines right half of screen
                                by dvu0627
                                I have a Sony Smart TV XBR65X900H that started to have horizontal lines on the right side of the screen (see attached picture). When I played video on Youtube green horizontal line at regular intervals(1/4") across the screen.
                                I replaced the T-Con board but the lines are still there.
                                I believe this issue is from the Main Board. Before I replace the Main board, I wanted to seek advise if this is the problem from the Main board or something else?
                                Thank you for the help....
                                02-05-2023, 03:39 PM
                              • Ihandyrepair
                                Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                by Ihandyrepair
                                Hi guys
                                I just started fixing 4k TV few months ago. so I am still learning a lot
                                I got this tv from friend complaint is ghosting or horizontal lines on image.
                                never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                then it started to show the ghosting white image.
                                I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                it has 3 thin small boards at the bottom of the...
                                12-05-2022, 04:18 PM
