super, thank you.
PSU TEST ON TV7001-ZC02-01 BOARD
Assuming...7 Photos -
Good day everyone,
Let me preface this with letting you know that I have a smalltime computer repair shop but do not have a lot of experience when it comes to board diagnostics. I am good at soldering etc but finding the issue if there isn't an obvious burnt component is not my strong suit.
The other day I got a customer come in with a macbook A1990 (motherboard 820-01814-A) that would not turn on and had previously been getting the warning message that the battery needed servicing. (Most folks seem to ignore that message, just like the check engine light in vehicles.)... -
by MalodicOneOriginal fault was customer spilled milk on unit, no corrosion was found on the board. Took mainboard out of original case and LCD and swapped it into the fully functioning case and LCD.
Shorts show up all over the board when trackpad is connected only. Trackpad is used and fully functioning from another unit of same model. Voltage injection causes trackpad connector to get hot but nothing else, swapped on board connector to rule that out, same issue. Diode reading on IPD_MCU_INT_CONN is higher then reference board @ .935 expected is .803. Shorts show up on PPVBAT_AON_CHGR_REG and... -
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... - Loading...
