Philips 47PFL4606 Powers on, works normal then powers off after a minute
  • simwalsh
    • Dec 2023
    • 4
    • Ireland
    I am new to this forum and have searched for some answers with problems similar to mine.
    Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
    It sounds like a power supply issue?
    I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v and tested 12v and 24v. Both 24V and 12V slowly go down while i'm reading them,12V never gets to 12V and quickly goes down. blue LED901 stays on for a few seconds and then dies.
    Any tips on what could be wrong or what to try next?
    Many thanks.
  • simwalsh
    • Dec 2023
    • 4
    • Ireland
    Update: did some further tests
    When turn power supply on with 1k resistor SB/+5V, across C907 i get over 327v dc then 400v then 327v after 3 seconds or so and when blue led goes off.
    At IC902 VCC pin 8 is 9.62V, across C946 i get 9.6V
    • simwalsh
      • Dec 2023
      • 4
      • Ireland
      ok thanks for the help here. /s
      For anyone that sees this message i fixed it by replacing IC905.
        • 12243
        • U.S.
        I would have helped but didn't see the post, might have helped to bump it every so often. Oh well, the last time I figured something out without any help I felt better than if it would have been spoon fed to me, anyway, good work.
        • simwalsh
          • Dec 2023
          • 4
          • Ireland
          no worries. i got the answer from someone with the same problem on another forum just took a little bit of digging, i wouldn't be able for advanced electronics
          • Instafixx
            Macbook A2179 820-01958
            by Instafixx
            Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
            The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
            I checked the Power Sequences below and found this -
            Once a valid external power source (Charger or battery) is connected, the following rails will come online.
            PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
            PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
            05-20-2023, 05:19 AM
          • djmka
            Philips 65PUS6554/12 - only powers on if you prime backlights first
            by djmka
            Hi everyone.
            I have a problem that I would appreciate some expert advice on.
            I have a 65” Philips television which powers on, has sound but but no picture. Usually this would lead me to believe an open circuit was present on the backlights. However, if I disconnect the mains power cable to the television and test the power cable going to the backlights using a LED tester, no open circuits are present. If I reconnect the backlight cable to the power board and replace the mains power cord to the tv the device fires up perfectly and displays a beautiful picture. It's almost as though...
            08-31-2022, 03:12 AM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • alro7779
            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
            by alro7779
            Hello, guys!
            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
            09-14-2025, 12:25 AM
          • G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
            by G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
            It does power up when pressing the power button.
            I already try the power button while plugin the plug with no result.
            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
            Could this be an PSU or eMMC issue ?
            07-19-2025, 03:43 AM
