Sony XBR-65Z9D won't turn on after lighting strike
  • Highvoltagerchelie
    • Nov 2023
    • 6
    Good afternoon. I found this forum as I was looking for troubleshooting information for my Sony z9d. A lightning strike hit very close to the house and did nearly $30,000 in electronics damage. The TV appears completely dead with no status light and no picture. I found the Sony XBR-65Z9D service manual and followed the troubleshooting steps on Pages 21-26. All checks seem normal except DC_OFF_DET check on Page 23 R420 voltage was slightly higher than 3V. It was 3.475V and C418 was slightly higher that the 5V at 5.3V.
    I proceeded to check the Power Board CN6401 connector. With all cables connected I have standby Voltage, Power On Voltage and all 12V when I plug in the TV. I do not have T_CON ON 3.3Volts nor do I have T_Con 12Volts. I disconnected all cables and provided a jumper from StandyBy Volts 3.3 to Power On and to T_Con On. T_Con 12 has 12V output now.
    I'm at a loss. I think its the BM2 board that has the fault, but not sure. Can you assist? I'm comfortable making all checks. I would like to repair at component level if possible.
    Thank you for your help!
    Click image for larger version Name:	IMG_2513.jpg Views:	2 Size:	2.99 MB ID:	3155803 Click image for larger version Name:	IMG_2511.jpg Views:	2 Size:	2.92 MB ID:	3155804 Click image for larger version Name:	IMG_2514.jpg Views:	2 Size:	3.24 MB ID:	3155805
    View and Download Sony XBR-65Z9D service manual online. GN2TR CHASSIS. XBR-65Z9D lcd tv pdf manual download.
    • Nov 2023
    • 6
    Pictures are attached in the post, but I can't see them.
    • EazyBone
      • Jun 2023
      • 1362
      • United states
      Lightning usually destroys the PSU or the main board in my research. The PSU has all correct voltages, so clearly the PSU can be ruled out. Likely your main board is busted now. If you had hdmis plugged into it or anything else plugged in, the lightning could have crept through those cords and popped the main board. Check for shorts all around the HDMI ports or whatever you had plugged in. Maybe something is burned by those ports.
      TCON on will occur when main board sends signal and since you jump tested then you should be all good. I assume you have voltages going to the LED driver board also right?
      And any voltage on the tcon fuse when plugged in on stby?
        • Nov 2023
        • 6
        I'm not sure which board is the LED driver board. I haven't removed the steel plate over the TCon board. I will check. Thank you.
        • Daren87
          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
          by Daren87
          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
          08-13-2023, 03:25 PM
        • iglitare
          by iglitare
          09-04-2025, 07:13 AM
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • rimwall
          Sony KD-65x7500D - double image - Tcon or Panel?
          by rimwall
          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
          11-18-2025, 02:09 AM
        • thelankanguy
          Sony KD-55X9000F TCON Issue
          by thelankanguy
          The TV shows a black screen with no image.
          TCON ribbon connectors were disconnected individually for image and there was no half image even.
          Later both ribbons were disconnected and TCON voltages were tested.
          12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
          There is also a short to ground in this circled inductor.
          Is this a TCON issue or something else ?...
          12-13-2024, 12:27 AM
