LG 50PK590 power fault and vertical line
  • Trune
    • 45
    • England
    Hi guys,
    Hoping you can help.
    The plasma initially had a vertical line down the middle of the screen but around the same time it also started to develop a problem with powering on. It does power on sometimes, but others not... It clicks then clicks off again shortly after.
    I have looked on the forum etc and found posts about the resistors in the top right of the board (eay60968801) and noticed repair kits on eBay also.
    However repair kits seem to mention 2 resistors of 22ohms however this board is 3 resistors of 10 ohms. I have checked all three and they are reading 10 ohms as expected.
    I also notice that a regulator 3BR1565JF and diode are in some kits (located at the centre of the middle heatsink). Is there any way for me to test these? Do I need to remove the diode to successfully test it? (As attached to the board it shows unexpected readings, but I imagine this is because it needs to be removed for accurate tests).
    Any help would be appreciated, could the two problems be related? Vertical lines and power? I imagine not to be honest but need to solve the power issue before continuing troubleshooting really.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 50PK590 power fault and vertical line
    yes. I hate to say it but most likely what is going on is your X driver IC on the panel is shorting out, loadding down the power supply VA voltage and then power supply goes into protection shutdown. Try disconnecting the two bottom ribbon cables that run the X drivers off of the control board. These are located at the bottom of the control (logic) board. Power up, see if it shuts down now. Note the screen will be all white thou. If no problems powering up its most likely an X driver IC embedded in the ribbon cable that connects the driver boards to the panel (not replacable) to that address shorted out. Or it can be the driver board.
    • Trune
      • 45
      • England
      Thanks for the reply.
      After taking the pics I reattached the board and the tv is staying on again at the moment (not particularly blizzard, it's been acting this way anyway).
      The line is still there, and it's staying on.
      As a coincidence I did some trial and error to try and find where huge fault may lie and I believe as it's a single pixel vertical line (green) in the centre it is X related or control board?
      I've tried reseating connections etc.
      When it plays up turning on again I will try disconnecting the ribbon.
      • freakaftr8
        • Oct 2012
        • 3743
        Its most likely the panel. LG plasmas seem to have this fault .you can always try to order a control board or try reseating the x driver cable but it may not help this issue.
        • munirutech
          • Oct 2013
          • 72
          • Ghana
          i think you have a bad panel is very common for lg and samsung panels and for the diode break one end to get accurate reading
          • Trune
            • 45
            • England
            You may be right.
            Although not ideal I located which ribbon was driving the vertical section of the panel and managed to connect it to a different x-driver. Unfortunately due to what I was able to display on the screen it was unable to be 100% sure but it did appear the line was no longer present.
            This would imply that it's either the centre X board or the controller. No way of verifying either without spares really.
            I have given the connector on the problematic ribbon a clean and will try that tomorrow but it's unlikely.
              Vertical individual lines are essentially always the panel. The X drivers only pass the clock, data signals and don't discriminate between individual lines.
              • Jabboy
                • Jul 2012
                • England
                Hi, Have u resolved this issue at all?
                I have the same TV which flashes blueish colour for a second and goes off.
                No picture or sound.I have tested the 10Ohm resistors and they are fine. all voltages from PSU appear normal?
                any help please?
                • TrueSword88
                  Kogan - KALED65XU9220STB - Blue Vertical Line
                  by TrueSword88
                  Hi all.
                  I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                  The line just happens to coincide with the end of COF and start of the next COF (attached).
                  The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                  Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                  Hoping to fix...
                  05-05-2023, 04:28 PM
                • almarhum
                  To fix laptop screen vertical line by working on its EDP cable
                  by almarhum
                  Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                  As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                  05-07-2024, 02:12 PM
                • mrsith
                  Samsung UE58TU7100K - no picture, vertical line
                  by mrsith
                  Hi.
                  Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                  This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                  Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                  02-07-2023, 11:18 AM
                • bdalkiran
                  55EC930V white vertical line appeared (need help)
                  by bdalkiran
                  Dear All,
                  I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
                  Please advice how to proceed and what is the...
                  01-13-2023, 04:16 PM
                • tmhobadcap
                  VIZIO M60-C3 Can the vertical line be fixed?
                  by tmhobadcap
                  I am trying to help my friend to fix his Vizio tv with a vertical line on the screen. The line is on the right side. It is blue/purple on the right side starting from the top. But it only goes to about 3/4 of the screen height (not to the bottom of the screen). It is very obvious when the screen is dark and it is hard to be seen when the screen is bright. Please help....
                  02-05-2023, 03:37 AM
