IS THIS NORMAL?? 330V DC From Bridge Rec. Only 245v AC Going In!?
  • max1636
    • Dec 2013
    • 80
    I'm working on a Sony KDL-46W5500, power board part no. 1-878-599-11, discovered something strange while probing around. I read 245v AC going into the bridge rectifier but 330v DC Coming out?
    Is this normal? I've never metered a mostly working board before so I don't know. I presume 330v DC is there because that's what the main cap is charged to?
    Re: IS THIS NORMAL?? 330V DC From Bridge Rec. Only 245v AC Going In!?
    That is a little low actually, the cap will charge up to the peak of the AC sine wave minus the voltage drop of the rectifier diodes.
    So 245Vac x 1.414 = 346VDC. Then you also have PFC voltage booster that will boost up to around 380~400VDC when TV is turn on.
    • max1636
      • Dec 2013
      • 80
      The problem with this set is that it powers on for some time with nothing on screen and no backlight, then turns itself off, blinks 13 times once, then blinks 14 times and repeats.
      All voltages on the connector to the control board (AV Input) are correct and standby voltage is correct. However there is no voltage going to the inverter board at any time. Are those big transformer that go to the inverter board known to go bad?
        That is the high voltage transformer, its output feeds the Balancer board which are then fed to the lamps. I doubt that it is the transformer.
        You should download the service manual to look up the error code for this chassis model.
        http://elektrotanya.com/?q=showresul...oria=&kat2=all
        • max1636
          • Dec 2013
          • 80
          Thanks heaps for that I'd been looking for a service manual that there alone probably just saved me another $60 I would of wasted on buying a new power board. 14 Flashes indicates a bad T-Con board, I've never had a bad T-con before. Could it be that fuse that I always here about on T-con boards that blow?
            Yes, check the fuse with Ohm meter first, then check for DC voltage (TV turn on) at both ends of the fuse with the meter black lead on the chassis for Ground ref.
            • max1636
              • Dec 2013
              • 80
              I can't believe it! The fuse is actually blown. I took the board out the other day to look for it but I couldn't find it but I was looking in the wrong place. I see a very small 7A Beside the logo would it be unsafe to bridge the gap temporarily with a piece of soldier of some kind of very thin wire?
                7A, that will be really high current for T-CON. Can I see the picture? Never seen fuse that size used on T-CON.
                • max1636
                  • Dec 2013
                  • 80
                  I also just definitely confirmed that it's blown, I'm getting 12v on one side, and not on the other.
                    OK, use the Ohm meter black on the chassis, red on the fuse's end to see if it shows low Ohm reading, we need to find out if the fuse just failed or the circuit has shorted out and caused the fuse to blow.
                    • max1636
                      • Dec 2013
                      • 80
                      It's difficult to measure since it's all over the place, on the side where the F1 is after having it on there for some time I get about 2 M Ohms, but it kept slowly going down, on the other side I get about 2 K Ohms, but it was slowly going up.
                        That is fine, as long as it does not show something less than 100 Ohms.
                        Here is the training manual for your chassis.
                        • max1636
                          • Dec 2013
                          • 80
                          Thanks! I really appreciate the help. So does that mean there is no short on the T-con and the fuse may of just blown?
                          My local electronics shop don't sell Surface Mount fuses I would probably have to get one online or just get a whole new board but just temporarily would it be a bad idea just to have a small piece of soldier across the fuse?
                            I use PICO II fuse with two legs, you can use 7A car fuse and any fuse you may have and solder the wire to the two end of the fuse or scrape off the Green coating on the board for you to solder the wire to. I will not try jumper just in case there is shorts further down the circuits that get switched on so the short will not show up when we do the inactive Ohm testing.
                            • max1636
                              • Dec 2013
                              • 80
                              I used a 7A Car Fuse but I get the same 14 Flashes. I The board must be bad then I guess so I'll buy a new one. Thankyou again for your help though I was going to buy a power board today so at least I'm buying the right one now.
                              • Ross Kohler
                                Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
                                by Ross Kohler
                                I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
                                - There's no sign of any attempt to power on when pushing the power button.
                                - No PSON signal is reaching the 24-pin ATX connector.
                                - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
                                - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
                                - If I pull the Super IO S_SLPS#_R pin...
                                04-16-2024, 09:36 AM
                              • Instafixx
                                Macbook A2179 820-01958
                                by Instafixx
                                Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                                The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                                I checked the Power Sequences below and found this -
                                Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                                PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                                PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                                05-20-2023, 05:19 AM
                              • cook
                                HP Power Supply 6632A: Fast Mode vs Normal Mode?
                                by cook
                                FAST MODE vs NORMAL MODE
                                I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
                                I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
                                06-07-2020, 05:32 AM
                              • Roman555
                                Asus H77 LGA1155 mainboard stopped working with Ivy Bridge CPUs
                                by Roman555
                                Bad symptoms when Ivy Bridge CPU (3rd-gen 22nm) is installed:
                                • Won't boot OS (just blank screen or stucks at asus logo, monitor is turned on) with hangs at debug (post) code A3;
                                • USB stick with MS-DOS can be loaded via F8 boot menu;
                                • Other OSes won't load - hangs or goes reboot;
                                • Postponed for several seconds reaction to Alt-Ctrl-Del, Reset and Power buttons;
                                • An operating system starts loading but won't finish if it's left only 1 CPU core in BIOS settings;
                                What I've already done and it hasn't helped:
                                • Cleared CMOS many times;
                                • Flashed different versions of BIOS in a CH341 programmer;
                                • Updated
                                01-18-2024, 06:26 AM
                              • Byte_76
                                Gainward GTX 295 SLI Bridge
                                by Byte_76
                                I have a Gainward GTX 295 with two PCB's which has a broken SLI bridge ribbon cable. As a result, the card is entirely useless and I'd really like to fix it if possible.
                                I've searched eBay and AlieExpress but haven't been able to find the part.
                                I believe this same SLI bridge cable is used on the Nvidia 9800 GX2 and the GTX 295 which both have two PCB's.
                                Can anyone help me on where to get a replacement SLI bridge cable please?
                                05-10-2024, 03:07 AM
