Tv lcd seeltech st2468dhd
  • cruyffcb
    • Nov 2013
    • 10
    • france
    Good morning.
    seeltech st2468dhd my TV starts when she wants. but not for long
    she died all alone. and once lit. if I change channels. it ceases to work. so I changed all chemicals on the power supply and the problem persists. by-cons. with scart it function well.
    thank you all. power helped me.
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Tv lcd seeltech st2468dhd
    Bonjour,
    Désolé, mais vous avez besoin de traduire car c'est un forum anglophone
    ce qui concerne
    • cruyffcb
      • Nov 2013
      • 10
      • france
      Idon't indesten. but thank you my fren for your reply
      • newtothis
        • Mar 2013
        • 1556
        • england
        Bon cela peut être très difficile de vous aider avec la barrière de la langue, ce que vous voulez dire changé tous les condensateurs?
        Translate : "Okay this may be very hard to help you with the language barrier, Do you mean you changed all the capacitors?"
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Seems like he doesnt have good English or French.
          Suggests it works with a scart so tuner problem? - Imported set? has France gone digital
          like uk making many sets obsolete overnight
          Possible arabic
          ZOBAIR MOHAMED
          @cruyffcb
          • cruyffcb
            • Nov 2013
            • 10
            • france
            yes my brother. I have changed all of the chemical capacitor 7 which is on the power
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              OK
              Can you tell us again what happens when you switch on?
              What do you mean about working with the scart?
              Have you read this:
              https://www.badcaps.net/forum/showth...t=15739&page=1
              Can you do those tests?
              Can you post pictures of YOUR boards.?
              Read this one again
              https://www.badcaps.net/forum/showpo...7&postcount=42
              • cruyffcb
                • Nov 2013
                • 10
                • france
                thank you very much for the answer. I changed these diodes. and chemical .470uf/16v and keep you running
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  Well done!! I think - are we done here - it is fixed -yes
                  • cruyffcb
                    • Nov 2013
                    • 10
                    • france
                    thank you my good man. I just changed the three chemical 470uf/16V. but I put the 25v.je think it does not matter
                    suite I changed "the two diodes. I put the 1N4007
                    now it hurts my eyes. I turn it on tomorrow morning and I'll let you know
                    • cruyffcb
                      • Nov 2013
                      • 10
                      • france
                      hello here I just changed these 2 diodes. and I put 1N4007. and I also changed the capacitor 3 470uf/16v
                      but the TV does not. backlight not start. before that changed all that. TV starts as well. thank you
                      • Genghis_Khan
                        ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
                        by Genghis_Khan
                        I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
                        Issue summary:
                        Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
                        However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
                        11-11-2025, 11:51 AM
                      • waigy
                        Help disabling scart pins
                        by waigy
                        I'm using this freeview receiver with this scart adapter.
                        When you plug in the scart adapter it routes the audio and video outputs to the rca connecters and it disables audio on the freeview speaker.
                        I want to use the video rca connecter but not the audio rca connecters.
                        This will mean it will play sound out of the freeview speaker and send video to the adapter.
                        If I remove pin number 4 (audio earth) from the adapter will this do what I want?
                        04-09-2022, 01:20 AM
                      • jimbofz
                        harwa 42 lcd tv no hdmi signal output
                        by jimbofz
                        theres no precise model number on the rear cover boards labelled as below
                        Hi just been given this lcd tv,
                        ive not come across this make before
                        there is no o/p from hdmi .its fine with scart .
                        good pic for its age
                        the main board is 782 L42W17-690B
                        cant find much info on google
                        to enter service menu .bring up a/v menu ,then 2580
                        but cant move to next page ,for options
                        (i was hoping ther may be an option to switch on/off hdmi/dvi)
                        the reason for this , is when hdmi is selected it says: no dvi signal
                        not: no hdmi...
                        01-06-2022, 05:57 AM
                      • rounin
                        MacBook A2338 M2 (820-02773) Not Charging
                        by rounin
                        Post:Hello everyone,I'm troubleshooting a MacBook A2338 M2 (820-02773) motherboard with a charging issue. Here’s the situation:Initial Fault:
                        • L8430 was burnt. After replacing it, the system worked normally for about two weeks, then failed to power on.
                        Current Symptoms:
                        1. Without Battery:
                          • When connected to power, voltage ramps from 5V to 20V, then drops back to 5V, cycling repeatedly.
                          • After disconnecting F5200, USB-C voltage stabilizes at 5V, and Pin 1 of F5200 measures 12V.
                        2. After Replacing U8100:
                          • With the battery connected, the system powers on normally, and the battery icon displays
                        08-06-2025, 11:24 PM
                      • popzeggey
                        Dell Latitude E7450 Power issues and fault
                        by popzeggey
                        I have a dell e7450 that shuts down abruptly when on and tries to restart. When the laptop attempts to restart, the hdd and wifi led is solid but power/battery led blinking hdd. Fault Description The memory modules are detected but encountered an error.
                        I have tried all basic troubleshooting steps like removing the battery and pressing power button for 30secs but issue persists. I have tried different fully working rams but issue persists. Any help would be much appreciated
                        01-16-2025, 04:31 PM
