MacBook A2338 M2 (820-02773) Not Charging
  • rounin
    • Aug 2021
    • 8
    • japan
    Post:Hello everyone,I'm troubleshooting a MacBook A2338 M2 (820-02773) motherboard with a charging issue. Here’s the situation:Initial Fault:
    • L8430 was burnt. After replacing it, the system worked normally for about two weeks, then failed to power on.
    Current Symptoms:
    1. Without Battery:
      • When connected to power, voltage ramps from 5V to 20V, then drops back to 5V, cycling repeatedly.
      • After disconnecting F5200, USB-C voltage stabilizes at 5V, and Pin 1 of F5200 measures 12V.
    2. After Replacing U8100:
      • With the battery connected, the system powers on normally, and the battery icon displays correctly, but it does not charge.
      • Without the battery, the same 5V-20V cycling issue persists.
    3. Replaced U5200:
      • Although I didn’t suspect U5200, I replaced it anyway. The issue remains unchanged.
    4. Battery Test:
      • Tested with a known-good battery (verified on another working board), but the fault persists (no charging).
    Measurements Taken:
    • With power + battery connected:
      • I2C_SMC_PWR_3V3_SCL ≈ 2.78V
      • I2C_SMC_PWR_3V3_SDA ≈ 2.78V
      • SYS_DETECT_L = 0V
      • C5220 resistance ≈ 2.2Ω
    Additional Info:
    • No signs of water damage.
    • I’m unsure where to check next.
    Can anyone with experience offer suggestions? Could this be an SMC or other circuit issue? What key points or signals should I check? Any help is greatly appreciated!
  • mon2
    • 14631
    Has the display assembly been replaced? Do you have True Tone? There was an issue earlier this year where the lcd assembly replacement will raise this fault.
    • rounin
      • Aug 2021
      • 8
      • japan
      Thank you for the help!
      the display has not been replaced, and I don’t believe this issue is related to the screen.
      When testing in a bare-board state (no display or other components connected), the power supply ramps up to around 19.5V (not quite 20V) and then resets, cycling back。
      • mon2
        • 14631
        If available, inspect entire board with a thermal camera. Search for hot spots.
        Remove all power. Meter in resistance mode. Measure the resistance to ground of each inductor. Suspecting you have a shorted part onboard. Post any low resistance inductors.
        This is power cycling.
        • rounin
          • Aug 2021
          • 8
          • japan
          Thank you mon2 for your continued support!
          Accidental Fix for Charging Issue:
          While re-measuring points around U5200, I made a mistake and accidentally shorted Pin 1 of R5215 to Pin 2 of C5216 with my probe,
          causing smoke! I thought I had completely ruined the board and felt terrible.
          I quickly disconnected the power and battery, checked the main circuits, and found no shorts.
          To my surprise, when I reconnected the power, the voltage stabilized at 19.7V—no more cycling!
          I then connected the battery, and the charging current reached over 1A. The battery started charging normally!
          It’s unbelievable—could this be some kind of “defibrillator” fix for the board?
          New Issue—Touch Bar Not Working:
          After reassembling the board, the system powered on fine, and everything seemed perfect… until I noticed the Touch Bar wasn’t displaying.
          Previously, after replacing L8430, the Touch Bar worked perfectly.
          I suspect the voltage spike from the short may have exposed or worsened an underlying issue, causing the Touch Bar circuit to fail completely.
          This might be the root cause of the original problem.
          Next Steps:
          I’m now troubleshooting the Touch Bar issue and will continue to update with my progress.
          Any suggestions on where to start with the Touch Bar failure would be greatly appreciated!
          • mon2
            • 14631
            Good that the board is working. The accident may have smoked out a partially shorted capacitor due to the high current surge. Now the part is no longer on the rail after this event.
            The touchbar is a complex design and still studying its operation. From what I know so far, the touchbars are available in different lengths for different macbook models.
            Each is based on a MIPI DSI 1 lane spec. According to Wentin, the interface operates in the low speed COMMAND mode of the MIPI DSI spec. The interface uses low voltage CMOS interface @ 1v2 swings.
            He goes very fast in his discovery process but is well documented here:
            https://www.youtube.com/watch?v=5TPB...WentingChannel
            PS: Working on some hardware to test the same. We killed far too much time in diagnosing a touchbar last week that was in the shop. In the end, there was nothing wrong with the touchbar. The bar only lights up after login using the user password. It is software based so be sure that your OS is not corrupted.
            Suggestions:
            1) boot using internet recovery with your network connection to boot a known good OS into RAM. Does this allow for your touchbar to work? If yes, issue is s/w based.
            2) If touchbar is still dark - seek out a known good touchbar for your model for quick testing. We did this and found even the new M1 / M2 touchbar we brought in for ~90$ (Canadian) was still dark. That is when we suspected that there is a logic board problem. Rabbit hole to hell.
            3) The SMD connectors used by the touchbar on these new models are @ 0.4mm pitch. Waaay too small pitched for my Fluke meter or scope. Respectively, took an old ATA ribbon cable in our junk pile and extracted a SINGLE naked wire out of the many conductors and wrapped it around our BLACK meter probe to create a needle like probe.
            Removed all power. Meter in DIODE mode.
            Red meter probe, yes red to ground on the logic board.
            Black wire tip to each pin to test on the touchbar connector. DO NOT, repeat DO NOT fall the mistake where we thought every pin was shorted to ground. The issue for us was that we were touching the METAL SHROUND (GROUND) around this custom HIROSE 26 pin connector. A rookie mistake.
            Be careful and touch only the signal contacts with a steady hand (no caffeine before this exercise). You are testing for valid DIODE measurements. If you see OL then it is very possible that line is OPEN or the EMI filter used on the MIPI lines is not soldered / damaged from a fall.
            Test:
            MIPI_DFR_CLK_CONN_FILT_P
            MIPI_DFR_CLK_CONN_FILT_N
            MIPI_DFR_DATA_CONN_FILT_P
            MIPI_DFR_DATA_CONN_FILT_N
            DFR_DISP_VSYNC
            DFR_1V8_DISP_INT
            DFR_1V8_DISP_RESET_L ; this line should NOT be in low state - if stuck @ 0v then it is stuck in RESET mode (you will have to measure in DC volts mode here)
            From what I know, if there are CLK and DATA lines on the MIPI DSI interface then the target display bar is capable of operating in MIPI DSI VIDEO mode = 80 Mbps or higher data rates.
            According to Wentin, the interface is being used in COMMAND mode = 10 Mbps.
            Either way, the DIODE mode readings for the above should NOT be OL on your meter. No power during DIODE mode testing.
            4) Test the voltage to ground of the I2C lines used by the DFR TOUCH = touchbar interface:
            I2C_DFR_1V8_SCL
            I2C_DFR_1V8_SDA
            5) Test the voltage to ground of:
            DFR_LID_OPEN_L ; if LOW, the lid is considered to be OPEN so the TB should enable
            PP5V_S2_DFR_FILT ; should be @ 5v
            PP1V8_AWAKE_DFR ; should be @ 1v8
            Post the details of the above and be patient. For us, it was a life sucking exercise because the client did not want to release her password. Understand but we killed hours in trying to fix something that was not broken. The root cause was the family dropping their macbook and creating a shorted cap on the LCD backlight voltage rail. A bit time consuming because our Qianli camera is too bulky to allow us to power up this logic board and take thermals.
            • rounin
              • Aug 2021
              • 8
              • japan
              Sorry for the delay in updating—I kept getting 400 errors due to server issues.
              Conclusion:
              After replacing LT711, everything is working normally (no issues found so far).
              After fixing the charging issue, the Touch Bar was not displaying, though touch input still worked.
              Measurements:
              PP1V25_AWAKE_IO ≈ 1.25V (normal)
              SPI_DFR_CS_L ≈ 1.25V (normal)
              DFR_1V8_TOUCH_CLK32K_RESET_L ≈ 0.6V (abnormal)
              SPI_DFR_MOSI ≈ 0V
              SPI_DFR_CLK ≈ 0V
              (I measured other points too, but can’t recall them now.)
              Troubleshooting Process:
              Checked LT710, and connectivity was fine, no issues found.
              When testing LT711, the tight space made probe contact unreliable, so results were uncertain. To be sure, I removed LT711 and noticed it had a chipped corner (possibly damaged by my tweezers or already defective).
              Regardless, I replaced LT711 with a new one, reassembled the board, and the Touch Bar now works perfectly—both display and touch functions are restored.
              Current Status:
              The system has been running for two to three days with no issues.
              • Orux
                Macbook Pro M1 A2338 13"
                by Orux
                I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
                I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
                One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...
                09-22-2025, 12:54 PM
              • sdogs
                macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                by sdogs
                Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                06-27-2025, 01:58 PM
              • sdogs
                by sdogs
                06-27-2025, 11:26 AM
              • classicandy
                MacBook Pro A2338 [820-02773] No Audio (Speakers and Microphone)
                by classicandy
                Hi Everyone,
                Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
                UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless ​a...
                04-14-2024, 12:00 PM
              • User555111
                A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
                by User555111
                Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
                02-05-2024, 08:16 AM
