LG 50PC1D Recurring Ysus Buffer Short
  • alanos313
    • Jan 2012
    • 10
    I have an LG 50PC1D plasma TV which suddenly lost picture, showing only an entire screen of moving coloured vertical lines. After a bit of research online, I found a post here http://blog.coppelltvrepair.com/2010...-lines-in.html which pointed to the YSUS buffers, specifically the MOSFETs which are mounted on them... I tested them as per the instructions on the page, and found two shorted FETs on the lower buffer. I replaced them, and the set worked perfectly, without any faults at all. For 30 minutes. Then the same problem returned.
    I checked the buffers again, and found that the third FET on the lower buffer had now shorted. So I replaced that one. Again, the set was perfect, this time for about 4 hours. Then it developed a thin vertical line on the right side of the screen, top to bottom. About 30 minutes later, another line appeared, on the left side, top to bottom.
    Around 30 minutes after that, the screen began to flicker on and off in roughly 1 second intervals, which is what happened just before it blew the FETs last time! I switched off and allowed it to cool down.
    I haven't checked yet, but I'm pretty sure I will find another shorted FET. Can anyone tell me what I can do to trace the cause of these shorts?
    Cheers
  • capkid
    • Oct 2010
    • 1339
    Re: LG 50PC1D Recurring Ysus Buffer Short
    It sounds like your Y-Sus may be faulty. Check your voltages, including VS, VA, VSC, and -VY.
    LG Plasma Mal-Discharge Correction Service
    • Tvbob
      tvbob
      • 204
      Change the board The FET is being turned on too long or it is working in to an abnormal load that you won't find with a volt meter.
      • DynaxSC
        Extreme High Current & Low Voltage Short Killer ??
        by DynaxSC
        Hi Folks
        I'm looking for a extreme high current short killer solution for a reasonable cost.
        I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
        After taking off the socket, the shorts dissappear again.
        The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
        10-15-2024, 10:13 AM
      • Stephen
        MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
        by Stephen
        I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
        02-06-2025, 12:03 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • Victor Moreira Silva
        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
        by Victor Moreira Silva
        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
        Well, my decice specs are the following:
        Model: Acer Nitro 5 AN517-54-55T5
        CPU: Intel Core i5-11400H
        GPU: NVIDIA GeForce GTX 1650
        Motherboard: GH51G LA-L181P Rev:1c
        The symptom:
        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
        05-26-2025, 10:49 AM
      • aaronkatrini
        Help me find the short circuit on this WORKING Nvidia GTX1650
        by aaronkatrini
        Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
        Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
        04-18-2024, 03:15 PM
