Hello guys. I have a samsung lcd tv with display issue. tv is working fine except the display is washed out / fuzzy / ghosty looking. i've posted some pic's hopefully an easy fix as its in great shape / condition other than issue stated. please let me know if there is any other info you would need. Thanks to all who reply
Samsung lcd tv #ln32a330j1d display issue
Re: Samsung lcd tv #ln32a330j1d display issue
This looks like a t-con issue to me. -
Post the picture of the T-CON board. it looks like AS15G Gamma IC problem on the T-CON board.Never stop learning
check the t con board if you find this ic
as15g or as15u or as15f if you find one of this then change itComment
Before we declare T-con as bad, need to check gamma voltages and VCOM.
VCOM: is marked as VCM. Expect around 7 to 8V.
Gamma voltages: GM1 - GM14. These voltages will start from 0V or 15V and go to 15V or 0V, monotonically (only increase or decrease; not both.) See attached graph. If there is a fault they will not look right and the image will look bad. Typically too white or too dark.
Test: red probe on point, black probe on chassis, multimeter set to volt DC (20V scale or autorange, whichever available.) Note: must use digital multimeter.Last edited by tom66; 12-27-2013, 03:12 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
This is the same T-CON as used in the LN32A300.
http://s807.photobucket.com/user/bud...tml?sort=3&o=2
It has bad AS15 as well.Never stop learning
It looks like a dimple on the body, it is 3.3V Fixed regulator, he can check the Voltage on that test point V33V.Never stop learning
I'm experiencing i similar issue. When the power is cycled by pulling the plug it appears perfect, then washes out to greyish white. I tried insulating (with index cards and tape) the frame from the chips on the bottom of the screen that connects the t-con and panel. I also reseated all cables, it looks like I may have the same problem. Did you experience the delayed greeting on power cycle? It is immediate for me after using the remote to power cycle. Have you solved the problem with a new T-con. Thanks
P.S. I have the LN32A300J1DXZA, which I believe to be near identical.Comment
Check the gamma voltages on the tcon, I've had several of these as15 ICs fail. Super-easy way to identify the problem. It should have a fairly steady ramp in voltage, but when they fail you'll get noticeable spikes and dips. If that's the case, then you can replace the IC yourself if you have the tools and experience. Otherwise, a repair service is good (I've used Coppell TV, doesn't hurt that they're local) for $40-50. Personally, I would be nervous about a replacement board since you don't know the age/history and may be looking at another gamma IC failure before long.Comment
Thank you for the help. The insulating did however extend the delay of normal picture to gradual fading to a bright grey by 2-3 seconds which has me hoping it's a grounding issue and not a ic failure. I will get back to you with voltages when home. Do I follow your instructions intended towards OP, with red marking? Can you also recommend multimeter settings. I'm also a bit uncertain on how to power the tv while accessing the t-con. T.I.A.Comment
Yes, follow the instructions provided above in the thread. You're looking at a range of approximately 0 (or close to it) ramping up to approximately 15v. It's nice to get a visual graph from your collected readings, it will help you see if the line is relatively smooth or has big dips and/or peaks. However, a lot of times I've found the highs/lows to be so pronounced that they're obvious from just looking at it.
For powering the TV, I've always left everything in place and simply removed the cover from the t-con board and hang my negative somewhere along the metal frame (I usually slightly insert it into a threaded hole to give it something to grip and hang from). So nothing special to note other than gaining physical access.Last edited by DLinkOZ; 06-24-2014, 01:47 PM.Comment
I have the same Tcon board in my Samsung and am having the same problem. The TV turns on and looks fine, within 2-3 seconds the picture fades until it looks just like OP's in about 10 seconds.
I tested the gamma voltages and they seem ok (0, 3, 3.8, 4.5, 6, 6.2, 6.7, 7, 7.7, 8.6, 10.9, 13
The VCM is only showing 0.13V, well short of 7!
It does have the AS15G IC, should I go ahead and swap that out or am I looking at a different issue?Comment
Are those the only voltages available?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Sorry for my carelessness. These are the 15 gamma voltages.
0, 3, 3.8, 4.5, 5, 6, 6.2, 6.7, 7, 7.7, 8.6, 9, 9.7, 10.9, 13
I was curious about the VCM, so I powered down the unit and watched the VCM voltage during startup. It started at 6v and steadily dropped, after 15 seconds it was down below 1v. Is that suspicious?
Thanks very much for your assistance.Comment
Yes, the VCM is suspect, and the other voltages look a little off to me, but I am not certain. I think AS15-F is the fault.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Thank you Tom. I will now try and source the part. I'm not sure how easy that will be in Canada. If it is within the forum rules for someone to suggest places near Toronto to try i would appreciate the guidance.Comment
The AS15-F part which requires good soldering ability to replace is widely available from China & the USA. The T-con board may be harder to source.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by FourRunnerI purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...1 Photo
by KjellAfter installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...08-01-2025, 09:15 AM -
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
- Loading...
