Back light problem
  • selldoor
    replied
    Re: Back light problem
    Pictures are nor really clear enough - need to be able to read the component numbers on the boards. When it is on can you tell if any bulbs are out (one corner dimmer etc.)
    We also need a pic of the inverter board and possibly the Tcon.
  • snipersquad100
    replied
    here's some pics
    replied
    Good clear pictures of the back of the TV and the boards so we can see what we are dealing with?
  • snipersquad100
    replied
    anyone
  • snipersquad100
    started a topic Back light problem
    Back light problem
    HI I've got an ALBA LCD32880HDF in with a back light going off after 30 secs or so. voltages are a bit of a problem as their not marked on the pcb. When it starts up im getting a 24v, 12v, 5.3v, 3.3volts when the back light goes off the 24v drops to 18v. So im not sure if I have a PSU or an inverter problem or something else.
    thanks
    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
    by sam_sam_sam
    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
    I am comparing them to a brand new one that I installed
    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
    I going to let it run for several days before I remount back on the wall next to the...
    09-05-2024, 06:48 PM
  • boyebaran
    hisense 65k560 back light problem
    by boyebaran
    hi to all
    tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
    in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
    please advise me tnx
    05-20-2025, 07:11 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • multimesut
    Dell 2007FPB Yellow Light Problem
    by multimesut
    Hello friends,
    A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
    11-13-2024, 07:00 AM
  • koby058
    vostro comes up with back light but no picture
    by koby058
    Hi people!!
    The owner said it showed bad picture once in a while (attached)
    I see that there is back light but no picture.
    I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
    Also attached schematic and BDV
    LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
    07-13-2025, 01:03 PM
