I've got a Mitsubishi Wd-65733 w/ main board part # 934c260002. The tv will not power on and just has a constantly blinking green light on the front. The light and ballast are fine, the power supply tests fine as well. I think it is in the main board, is there something to look for on this to get it to turn on? The troubleshooting codes give nothing to go by.
Mitsubishi WD-65733 Main board caps
Re: Mitsubishi WD-65733 Main board caps
Timer LED Does Not Stop Blinking
Cause 1
1. Suspect the Main PCB part # 934C260002
you want be able to put set into on board diagnostic mode because the set is not able to go through and complete the boot cycle this why you have the continues flashing of the light. Normal operation light would quit blinking after about 60/70 secs then power on would be allowed, main board replacement only option and don't forget to consult service manual cause after board replacement your going to have to enter service mode and copy over the alignment data and geometry data from optical engine back to new main boardLast edited by RON_CET; 12-15-2013, 06:26 PM.Ron Driver,BSEE,CET,ISCET,NESDAComment
@newtothis ... I believe I have reasonable abilities. What did you have in mind?
@RON_CET ... I have the service manual but I'm not sure how to put set in diagnostic mode to complete the boot cycle. I agree with the normal light operation as this is my personal tv that I use regularly, it would let you power on after 60/70 secs. How would you be able to retrieve the alignment data and geometry data (assuming through the diagnostic mode)?Comment
going into diagnostic mode will not complete boot cycle, i was just explaining that you can't go into diagnostic mode until the boot cycle completes it loading sequence hence light stops blinking, here's snap shot of some reading from page 32 of service manual which tells you about transferring the data once new main board replacedAttached Filesif you find these attachements useful please consider making a small donation to the site
I understand now what you meant. Is there any repair to the original board (i.e. replacement of caps) that you see being possible? Or buy a used one from ebay. Or buy new (reconditioned)? Is there a certain part of the board that I should look first for diagnosing a possible fault? ThanksComment
As a Authorized service for Mitsubishi I'm not aware of any quick fix tips for this issue,board replacement for the blinking issue is a Mitsubishi Tech triage recommendation
from Technical center. as for purchasing board ShopJimmy, Paylesscomponets,union Electronics,Encompass I'm not big fan of buying off Ebay most of the Sellers have no way of testing what there selling so you 50/50 chance unless there giving a decent return policy on DOA itemsRon Driver,BSEE,CET,ISCET,NESDAComment
I've purchased things from them before. There's not much of a challenge in just replacing a board. If that's what it ends up being I suppose I will.
I've checked a couple of the regulators, fuses are good as well. There are a few test points labeled with voltages that seem to be ok. Is there other things to be looking for.
I've heard the caps on the board can be a big problem and if I replace all of them (99 I think) that should allow the set to complete the boot sequence. I'd try and tackle that if there is some truth to it. I remember there was no sign of this problem occurring before it just happened. I had tried to turn on the tv when I noticed that the timer light was constantly blinking with no response.Comment
How do you know the lamp and ballast are good ?
You sound like a capable fellow - if these are electrolytic caps I would by an ESR meter instead of 99 caps and future proof yourself against further issues of the same type and only replace what's necessary.Comment
I was able to send a signal to turn on the ballast and the lamp started to light, but with no fans running I let it turn off. I replaced the lamp recently (1-1.5 yrs) and I used a Osram lamp that has worked really well.
I don't have an ESR meter. Would I be able to test them on the board? If I had to take them off to test, I'd probably go ahead and replace anyway. What ESR meter would you look at buying? I do like to have nice equipment, but I don't have to have the best of the best. I just want it to give me an accurate measurement everytime.Last edited by weimars; 12-16-2013, 08:01 AM.Comment
Yes you can test them on board, but it is still preferable to remove them for testing unless you have a good idea of the circuit they are a part of but keep in mind those caps you're looking at will likely not have signs of damage they will have high esr and this will be detectable in circuit.
There is this
https://www.badcaps.net/forum/showthread.php?t=32989, though it gets convoluted at times
and this
https://www.badcaps.net/forum/showthread.php?t=32989 to get you started.
Good luck.Comment
Your links go to the same page. Did you have a different thread in mind?Yes you can test them on board, but it is still preferable to remove them for testing unless you have a good idea of the circuit they are a part of but keep in mind those caps you're looking at will likely not have signs of damage they will have high esr and this will be detectable in circuit.
There is this
and this
Good luck.Comment
I was going to replace a few caps on the main board in an effort to rule out a few suspects. I've read a few forums here that suggest using Panasonic FR (FM, FC...) series caps for the ultra low esr. I've got some Rubycon PX series (through hole) caps that was going to use. My question is are they not a low enough esr to function properly?
Second question: There are many caps that have similar ratings (i.e. 6v 47uf, 16v 100uf, 16v 10uf...), can I use one size cap that would accommodate the bulk of these caps (i.e. 16v 100uf)? There seems to be no physical size restrictions.Comment
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by ygorsanHi everyone,
Iām looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
š§© Problem Summary:- The TV keeps scrolling through the menu or selecting items by itself.
- I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
- The remote control is not in use (batteries removed), and the TV still shows the same behavior.
- I
07-28-2025, 08:34 AM -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... -
by JDCONN 100012588
Issue: No Power, Then Rebooting After Main Board Change
Short answer: replace main board and power board
Technical answer: replace main board and Q306 & Q307 on power board.
Long answer:
TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge.... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... - Loading...
