Westinghouse SK-32H540S
  • CraigR
    • Dec 2013
    • 973
    Re: Westinghouse SK-32H540S
    Same as before.
    • selldoor
      Slow Learner
      • 7870
      Just to be sure - you did replace IC712?
      When you were testing caps did the 2 attached to that VR check out ok
      • CraigR
        • Dec 2013
        • 973
        Yes and Yes however after posting my last response the mail came and in it was a mainboard I got off eBay so I put that in and now it's working again. So thanks for all the help! Now if you could only help me with fixing the Haier TV that I posted a problem with.
        • selldoor
          Slow Learner
          • 7870
          Great! but frustrating - another mainboard we couldnt fix well at least not quick enough.
          • dhack61
            • Aug 2010
            • 33
            Well maybe somebody can help me with mine, Have the same problem
            All voltages from PS correct, no signal voltage to BL_ON. No standby light but, I can press the power switch and the main blue light does come on.
            Checked all VR's and they are fine and to spec.
            So whats next in this process?
            • CraigR
              • Dec 2013
              • 973
              Replace the main board.
              • dhack61
                • Aug 2010
                • 33
                #27
                LOL.... Yes that is true. I could spend another 40 bucks on this thing. Cheaper would be better
                • Dvsr
                  On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                  by Dvsr
                  Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                  I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                  After replacing the caps I started testing out the speaker. It seemed...
                  09-10-2025, 10:20 AM
                • caspian
                  What Zener Diodes on a Linear Power Supply
                  by caspian
                  Dear members,
                  I have a linear variable power supply with unknown brand name that I used for voltage injection.
                  Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                  In addition, I discovered that its zener diodes are defective.
                  I can replace the burned transistors.
                  But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                  Therefore, I cannot replace the zener diodes.
                  I do not want to test the zener diodes in a test circuit to discover their model or value.
                  no schematics are available...
                  05-26-2025, 12:38 PM
                • jordanaudio1
                  Samsung TV UN60KU6270F power supply
                  by jordanaudio1
                  Trying to learn electronics repair as a hobby. I have no formal training in electronics, circuits, etc. Everything I know, which isn't much, has been learned from watching youtube videos, reading books, forums, etc. This means, sometimes I have a hard time understanding and interpreting what's important when I look at datasheets, and such.
                  My brother has a TV that I'm working on now. He said he was watching it, he heard a loud pop and it went off. I used my DMM to check the fuse, it was blown. From watching lots of hours of electronics repairs on youtube, I figured that was just a...
                  07-07-2025, 07:38 PM
                • KYBOSH
                  Wine and Beverage Cooler Control Board Repair Attempt
                  by KYBOSH
                  Trying to a fancy Wine and Can Beverage Cooler which wasnt working.
                  Model number AWBC242GGFD
                  Previous owner states that it needs a new motor.
                  When plugged up you hear a quick chime from the PCB alarm but it quickly dies away (trails off actually) and there is no sign of life from the unit at all.
                  I pulled out the main control board to give a look.
                  Fuses checked out okay. All diodes except one checked out. It was reading in both directions so I pulled it out of circuit and checked it again but this time it read good.
                  07-18-2024, 11:52 PM
                • Nikolai Danylchyk
                  Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
                  by Nikolai Danylchyk
                  Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
                  Thanks in advance!...
                  05-08-2025, 06:18 AM
