Philips 37PF9975 - comes on and shuts off
  • Jooo
    • Oct 2011
    • 222
    • Finland
    I have this Philips 37PF9975 plasma TV. When I turn it on, relay clicks, green light comes on, faint buzzing sound, panel goes on (but no picture) and then within couple of seconds relay click and it shuts off.
    I found tom66's thread with same model TV here
    If I freeze those four 10nF 630V ceramic caps, it will do exactly the opposite than what tom's did: it will shut down quicker, and the panel doesn't come on.
    When I heat the area the panel will come on again for couple of seconds and then shut off.
    By the way all of those 10nF ceramic caps measure 17nF, is this allright?
  • Jooo
    • Oct 2011
    • 222
    • Finland
    Re: Philips 37PF9975 - comes on and shuts off
    Found the fault - two 100uF 16V SMD capacitors - one measures 3,1ohms, another one measures 11,8 ohms. Heated these up and the tv stayed on.
    The question is, can I replace these with regular through-hole capacitors?
      Yes, I would use glue to secure them though.
      • Jooo
        • Oct 2011
        • 222
        • Finland
        Thanks. It turned out that actually almost all of the SMD caps were bad.
        Only four tested good.
        There were also two bad Rubycon YK:s, a 220uF 25V and a 22uF 50V. I replaced them with Rubycon YXA 220uF 35V and 22uF 50V.
        This is what I used for the SMD caps:
        100uF 16V - Nichicon PW 100uF 25V
        47uF 16V - Chemi-Con KME 47uF 25V
        22uF 35V - Rubycon YXA 22uF 50V
        4.7uF 35V - Chemi-Con KY 4.7uF 50V
        2.2uF 50V - Panasonic FC 2.2uF 50V
        There were also two 10uF 100V and one 1uF 100V SMD cap that I left because I had no replacements on hand for them, but they tested good.
        The 22uF 35V capacitor tested open, most of the other caps had over 10 ohms ESR. Few of the old caps had over 20ohm esr.
        I soldered the new caps in, turned the TV on and its working flawlessly
        Another TV saved from landfill.
        • vernond
          Philips 42PFL3609S/98 Shuts down after sometime
          by vernond
          Hi.
          I have a Philips 42PFL3609S/98 TV that shuts down after some time. If the TV is not power overnight and is powered on in the morning then it will last longer sometimes up to 2 hours. After the first shutdown, it will be more difficult to switch it on again. It would be easier to restore power if I remove the AC cord and plug it back again.
          Replacing capacitors C805 and C804 didn't solve the problem but made the running time last slightly longer. The old capacitors were giving me a reading of 920 uf. C840 and C840A are giving out a reading of 72uf and were not replaced....
          08-19-2021, 08:02 AM
        • alro7779
          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
          by alro7779
          Hello, guys!
          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
          09-14-2025, 12:25 AM
        • G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
          by G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
          It does power up when pressing the power button.
          I already try the power button while plugin the plug with no result.
          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
          Could this be an PSU or eMMC issue ?
          07-19-2025, 03:43 AM
        • huzo
          HP Omen shuts down when loading OS
          by huzo
          The model is 15ec-1061nm
          Board number is DAG3EDMB8D0​
          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
          10-29-2024, 12:05 AM
        • Giggle2562
          Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
          by Giggle2562
          I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
          The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
          Here's what I've tried so far:
          • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
          • The laptop shows an image on the internal display for a few seconds before it shuts down.
          • I tried swapping the LCD panel with a known good one.
          • I tried swapping the LCD cable
          11-06-2025, 12:36 PM
