Error code 14 blinks found 3amp ceramic fuse on TCon board blown. Replaced fuse and tried T again with both panel connectors not connected on top of Tcon board. Screen lights with dark grey picture and green led power light on. Powered TV off reconnected both panel connectors this time after a few seconds with green led lit error code 14 starts flashing again. Found that attaching the panel connectors caused the fuse to blow again. Is it likely its a bad tcon or more likely a bad panel thats causing this fault?? Anybody any ideas?? Grateful for any comments.
Sony KDL40D3500 14 blink code
Re: Sony KDL40D3500 14 blink code
More likely to have shorted out TFT driver IC, or shorted out caps (MLCC) the long board where the LCD flexible PCB is attached to, the TFT ISs are on the flexible PCB. So not likely to be repairable.Never stop learning
by reporter1979Hi all, the TV KDL-40W2000 was flashed by a lightning.
Firstly I got the 3 red blink code.
Following other threads I changed the power supply board and got always 3 blinks.
So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
What else can I do?... -
TCL LED TV Service Menu Code
LG LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
I have this set. It turns on and is watchable for a few minutes but then shuts off and flashes 4 red lights.
I don't work on Sony much but assumed it was backlights from what I read.
Opened up the TV and tested all the backlights with led tester and the all work.
I know sometimes that doesn't mean anything since it's not running at full current but I hate to spend $120 on backlights (shopjimmy) is the only one that even has them just to find out I missed something.
So anyway to test these lights similar to the way we test... -
by rmacintoshI aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
The symptoms of the tv ar as follows:- Plug AC in to back of TV
- After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
- The 3 blink code is given by the power LED
- If the TV is unplugged and then
by FamoHello badcaps forum.
I have a Sony KDL-52Z4500 TV that needs a little trouble shooting. History of the TV: I bought it about 14 years ago. One year ago, I took it off the wall to move to another house. During the past year it sat in its original packaging - even with the thin film plastic bag/cover that it gets shipped in, cardboard box and all. Last week I unpacked it to mount it in the garage for my wife's gym that she has setup. Turned it on, set up a chormecast on it for her, and all was good for a week running like always (brownie points for me from the wife).
...06-09-2023, 10:21 PM - Loading...
