Samsung LE40M86BD flashing picture
  • Gomez75
    • Dec 2013
    • 6
    • Uk
    I have a Samsung LE40M86BD LED TV, the picture has recently started to flash, i have turned it on and off a number of times and a few wiggles of the HDMI lead occassionally sorts it out. I have read somewhere that there is a jumper that can be cut on samsungs and this remedies the problem. Howvere the jumper no. stated on another model does not appear on this model
    Could anyone offer some advice? I have been into service mode and reset but this has had no effect.
    Cheers Gomez
    Re: Samsung LE40M86BD flashing picture
    When it flashes, does the backlight go out too, or can you see a glow between each flash?
    • Gomez75
      • Dec 2013
      • 6
      • Uk
      The picture flickers and when the scene changes the old scene fades on one side of the screen.
      • johnboy1313
        • Nov 2012
        • 1959
        Sounds like a tab-bond/panel failure issue.
          Yeah I'd have to agree.
          • Gomez75
            • Dec 2013
            • 6
            • Uk
            what would be the best remedy?
            • johnboy1313
              • Nov 2012
              • 1959
              Do a search on this forum for "tab bond repair"
              • Dang
                • Aug 2013
                • 440
                Try here: https://www.badcaps.net/forum/showthread.php?t=33616, this has been my experience of resent times, do remember though it could either be on the driver board or directly on the LCD screen.
                • Gomez75
                  • Dec 2013
                  • 6
                  • Uk
                  if i were to purchased any pads for repair do you recommend any?
                  • Painker
                    • Nov 2014
                    first of all sorry for diging out this old thread. I´ve got the same Tv, the Samsung LE40M86BD. But my backlight is flashing. I replaced the caps a year ago. The tv was working fine after this. But now the backlight is going on and off rapidly. Just like a strobe.
                    I´ve replaced the cap´s again but nothing changed.
                    What do you think? Maybe the inverter or the power suply board?
                    Sorry for my bad english. I´m from germany
                    I would be thankfull for any advice.
                    Greets Painker
                      09-07-2024, 05:50 AM
                    • JJAAMM
                      by JJAAMM
                      Problem
                      07-06-2023, 06:01 AM
                    • estergon2004
                      Samsung LE37A656A1F TV, No Picture, LED Flashing Continuously
                      by estergon2004
                      Samsung LE37A656A1F
                      TV turns on, no picture, LED light flashes very rapidly and continuously .
                      Sound and Backlight are OK.
                      It didn't happen at once.
                      In the beginning picture was coming about 15 mins after the turning on.
                      What could be the problem please?
                      Thanks!
                      05-27-2023, 03:57 PM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • learnmore
                      Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                      by learnmore
                      Hello Community!
                      CASE DETAILS
                      Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                      13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                      Tried inserting firmware on USB and left it in for a few hours, but no change
                      03-03-2024, 09:49 AM
