E470VL Power Board Replacement/Substitute
  • RichWeber
    • Nov 2013
    • 23
    Hi Guys.
    I have done some troubleshooting in another thread, and attempted a repair that did not work. So now I'm to the point that I need to replace the power board.
    Problem is, I cannot find a power board from a reputable source that is in stock. I'm not sure if it's made anymore or not. My board is part number 3PCGC10016a-R. Manufacturer part number 0500-0412-1000. Everywhere I look it is out of stock.
    http://www.shopjimmy.com/vizio-0500-...upply-unit.htm
    I have found another board that is part number 3PCGC10016c-R The pinouts are the same. The board is the same size, and has the same formfactor right down to the mounting holes. The part number is 3PCGC10016c-R. Manufacturer part number 0500-0412-1290 or 0500-0412-1360.
    Here are shopjimmy's pages for the part number, and both manufacturer part numbers.
    http://www.shopjimmy.com/catalogsear...=3PCGC10016c-R
    http://www.shopjimmy.com/vizio-0500-...t-inverter.htm
    The only difference is, that on the power out to the main board the pins that are 5v on my board are 5.2v on the 3PCGC10016c-R. Otherwise everything looks the same. As I said, the layout is exactly the same as my board. Would that board be suitable? Will that .2v hurt my main board in any way? Also of the two boards, which one should I get, the 0500-0412-1290, or the 0500-0412-1360?
    Thanks in advance guys.
  • RichWeber
    • Nov 2013
    • 23
    Re: E470VL Power Board Replacement/Substitute
    Nevermind. I found one on ebay.
    • davidkvasquez
      • Apr 2017
      hi all!
      never intended to have my very first post up here be one that resurrects a thread from the dead, but coincidentally enouh, here I am!
      That being said, it's now been four years since the original poster made the inuiry and here II am in 2017 wondering the same. Hard to find this specific part number as well as the repair kits... Ideally I would find the component that has failed and repace it, but my time is limited as well as my knowledge of smps testing. Ive read quite a few threads here and do have an oscilloscope;
      I am not getting the 12v run side voltages from my p.s. and beyond that I don't know much else to test..
      Thinking back. I actually may have gotten the 12v out when I used 2 double a batteries to supply the on signal to the board which, if it was the case then that means my power button or main board has failed, but not sure how to test the power button since all terminals on the power pcb have some level of continuity although somewhat high ( a few k-ohms ? )
      WELL ANywaY that was quite the digression but as you can see I'm running out of options Lol
      thanks for listening to/reading my babbling and for any help these mighty and wise forum participants provide!
      -Dave the mechanic
      • dskall
        • Oct 2016
        • 2905
        • usa
        Need good clear straight on pictures of board and connector.
        • boosti45
          Macbook pro logic board replacement parts quesion
          by boosti45
          i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
          08-21-2024, 05:23 AM
        • tuner2000i
          Philips 65PUS8518/12 distorted image after main board replacement
          by tuner2000i
          hello everyone,
          I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
          The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
          07-15-2025, 01:15 PM
        • Cvrado
          Led TV Board Replacement, same part number and model, different size
          by Cvrado
          Hello my friends!
          I have a question that I think you can answer and help me with!
          I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
          So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
          My concern is that the board won't draw enough voltage to the bac...
          03-02-2024, 05:05 PM
        • snipersquad100
          Dewalt DCR020 Power Board – No Power, Need Help Identifying ICs / Possible Replacement
          by snipersquad100
          I’m working on a Dewalt DCR020 jobsite radio that won’t power on.
          So far, I’ve checked the following:
          • The mains is reaching the transformer
          • Transformer outputs ~15-20 V AC
          • Bridge rectifier outputs ~15-20 V DC
          • All fuses test OK
          • The on/off button signal reaches the PCB connector
          Despite this, the unit does not power up at all.
          Inside, I’ve identified some of the ICs:
          • ST7317 (appears to be an LCD driver, not the main MCU)
          • LM2937L (voltage regulator)Not putting out power, 0.5V on the input
          • Markings like FS1235, unknown IC
          • Board number:
          09-01-2025, 10:57 AM
