Orion SLED4668W no power
  • Kevlar1307
    • Nov 2013
    • 10
    Looking for some guidance,
    I replaced the power supply in this tv about 6 months ago after a power surge. It fixed the tv until recently when I quit working again. No red LED on the front or anything. I figured it was the power supply again and replaced it but this time that did nothing. I'm at a loss what to try next.
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Orion SLED4668W no power
    good quality pics of boards, one of entire back of set (so we can see all boards)
    Do you have a DMM?
    • ricobr54321
      • Nov 2018
      Orion sled4668w no power, no blinking light, no smell or indication of damage inside. Tested power input, tested continuity of power cord, preformed smell test, no schematics or troubleshooting direction found!
      Possible places to test?
        For us to help we will need good clear pictures of the whole backside of the TV showing all the boards, and the straight shot pictures of the whole top and bottom side of the power supply board so we can read the printed texts on the board.
        It is hard to do long distant troubleshooting without seeing what we are dealing with.
        What is the history of the TV? Any works were done to the TV before?
        The more details we get the better chance of finding the cause of the problem.
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • bcstedt
          LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
          by bcstedt
          LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
          Problem:
          On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
          It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
          01-18-2024, 01:03 PM
          by sam_sam_sam
          03-31-2024, 02:12 PM
        • MicroSMD Lab
          MSI MS-16W1 no power, EC replaced by other.
          by MicroSMD Lab
          Hi, I'm working on a MSI laptop, Motherboard number MS-16W11, GF-65 Thin 10SDR-459US. Went to another shop because the screen was flickering, but it was working well on an external monitor. The LCD was ordered and the laptop was returned to the customer and it no longer worked. It was then sent to another tech (by the shop who ordered the LCD) and the EC (ENE KB9028Q) was replaced with a donor from another MSI board with different board number and no programming was done. It looks like work was done on PU6 (TPS51225) as well as one of the GPU mosfets was burnt (I removed all three GPU mosfets)....
          03-27-2025, 07:35 AM
