Samsung LN32C450 - Audio but no video
Re: Samsung LN32C450 - Audio but no video
Hmm, in the user menu, you will have to use bright light, but try turning the backlight setting up to either full bright or minimum brightness, does it have any effect on behaviour?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Ran the both the backlight and the brightness from 0 -> full. No change. Tried this with BUL_ON (Wire #4) connected and disconnected. No change.Comment
There is a large, 450V yellow capacitor in the middle of the power board. With your multimeter set to the highest DC range, what voltage do you measure across it? Caution: high voltage, expecting around 390V. Do not touch any multimeter probes and avoid shorting them together or you could damage the power board. Test to be done with TV plugged in and powered on.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
That voltage is normal. Can you check if you have good 24V going to the inverter board? To test, put your multimeter red probe on each of the pins going to the inverter and black probe on chassis, noting the voltage.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
1 - E-PIN: 1.0
2 - NC: 0
3 - BLU_ON: 5.1
4 - INV_ERROR: 1.6
5-9 GND
10-14 - B24V: 28.5V
Probably means nothing, but just something I experienced: When I unplug the AC plug from the back of the TV the blacklight flickers on/off but when I power down the TV through the front panel it does not.
Anyway, do you see anything peculiar in these voltages?Comment
Please double check 24V because 28.5V is much too high.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Keep getting 28.5V. Done this on three separate days both on the inverter and PSU boards.
Is there a way to test if my multimeter is calibrated correctly?
It's new, on the 200VDC setting, so maybe it's not as accurate for 24V? Can't use 20VDC..Comment
Test a fresh AA battery, 1.5V expected.
A high 24V can cause the inverter to shut down, so this can cause your fault. Typical operational limits are 22.5V to 26.5V.Last edited by tom66; 12-13-2013, 06:50 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Referring to schematic,
the B13V is unregulated, which is typical. This means if the 24V is out, the 13V should be out by a corresponding amount, in most cases. The 24V is labelled 24.5V nominal, which is more or less typical. If it is giving 28.5V, I would expect around 14.5~15V on the 13V outputs. Do you observe this?
I also notice this PSU incorporates overvoltage protection which should fire at around 27V + ~1.5-2V = 28.5-29V on 24V so the PSU is very close to cutting out.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Hmm, that is quite high. Maybe not quite as high as expected, but a lot higher than the normal ~13.5V that a Samsung operates on. This could be the cause of the fault.
Can you see a device labelled "ZDTM851" on the top side of the power board? It should be near PC803S device.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
This can be seen on the psu board picture in the original post. Also notice that the camera flash shows the board as shiny. Not sure what caused this, but the top left portion of the psu board has this shiny look to it, with the edge of the board actually showing mold spots.Comment
