Samsung LN32C450 - Audio but no video
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Samsung LN32C450 - Audio but no video
    Originally posted by Aulus
    Well that was correct, but now all of a sudden after unplugging the AC for a while it went back to turning on the backlight when the PSU-Main cable is D/C.
    The symptom that I've seen change is that upon turning off the TV it now flickers the backlight once, then stays dark.
    Is this with the PSU - MAIN connector plugged in?
    • Aulus
      • Dec 2013
      • 27
      Yes. With the PSU-MAIN connected and wire #4 D/C, the flicker occurs on powering down.
        Hmm, in the user menu, you will have to use bright light, but try turning the backlight setting up to either full bright or minimum brightness, does it have any effect on behaviour?
        • Aulus
          • Dec 2013
          • 27
          Ran the both the backlight and the brightness from 0 -> full. No change. Tried this with BUL_ON (Wire #4) connected and disconnected. No change.
          • Aulus
            • Dec 2013
            • 27
            Any more thoughts on where to go from here?
              There is a large, 450V yellow capacitor in the middle of the power board. With your multimeter set to the highest DC range, what voltage do you measure across it? Caution: high voltage, expecting around 390V. Do not touch any multimeter probes and avoid shorting them together or you could damage the power board. Test to be done with TV plugged in and powered on.
              • Aulus
                • Dec 2013
                • 27
                TV plugged in: 160V
                TV plugged in and powered on: 384V
                • Aulus
                  • Dec 2013
                  • 27
                  Any thoughts on what I can try next?
                    That voltage is normal. Can you check if you have good 24V going to the inverter board? To test, put your multimeter red probe on each of the pins going to the inverter and black probe on chassis, noting the voltage.
                    • Aulus
                      • Dec 2013
                      • 27
                      I'll list the pins and their corresponding voltages:
                      1 - E-PIN: 1.0
                      2 - NC: 0
                      3 - BLU_ON: 5.1
                      4 - INV_ERROR: 1.6
                      5-9 GND
                      10-14 - B24V: 28.5V
                      Probably means nothing, but just something I experienced: When I unplug the AC plug from the back of the TV the blacklight flickers on/off but when I power down the TV through the front panel it does not.
                      Anyway, do you see anything peculiar in these voltages?
                      • Aulus
                        • Dec 2013
                        • 27
                        Thoughts on the next step?
                        Also, thanks for your help thus far. It's been a learning experience and quite entertaining
                          Please double check 24V because 28.5V is much too high.
                          • Aulus
                            • Dec 2013
                            • 27
                            Keep getting 28.5V. Done this on three separate days both on the inverter and PSU boards.
                            Is there a way to test if my multimeter is calibrated correctly?
                            It's new, on the 200VDC setting, so maybe it's not as accurate for 24V? Can't use 20VDC..
                              Test a fresh AA battery, 1.5V expected.
                              A high 24V can cause the inverter to shut down, so this can cause your fault. Typical operational limits are 22.5V to 26.5V.
                              • Aulus
                                • Dec 2013
                                • 27
                                On 200VDC it read spot on for the AA Battery.. 1.5V
                                  Referring to schematic,
                                  the B13V is unregulated, which is typical. This means if the 24V is out, the 13V should be out by a corresponding amount, in most cases. The 24V is labelled 24.5V nominal, which is more or less typical. If it is giving 28.5V, I would expect around 14.5~15V on the 13V outputs. Do you observe this?
                                  I also notice this PSU incorporates overvoltage protection which should fire at around 27V + ~1.5-2V = 28.5-29V on 24V so the PSU is very close to cutting out.
                                  • Aulus
                                    • Dec 2013
                                    • 27
                                    The 13V is reading 14.2V.
                                      Hmm, that is quite high. Maybe not quite as high as expected, but a lot higher than the normal ~13.5V that a Samsung operates on. This could be the cause of the fault.
                                      Can you see a device labelled "ZDTM851" on the top side of the power board? It should be near PC803S device.
                                      • Aulus
                                        • Dec 2013
                                        • 27
                                        I found it on the under side, but cannot find it on the top side. Here's where the chip is at: Top left part of the board and just 1/8" up-left of the plastic support post. Should I be able to trace it or what do I do?
                                        This can be seen on the psu board picture in the original post. Also notice that the camera flash shows the board as shiny. Not sure what caused this, but the top left portion of the psu board has this shiny look to it, with the edge of the board actually showing mold spots.
                                        • Aulus
                                          • Dec 2013
                                          • 27
                                          Also, retested the 24V wires with the backlight ON. I did notice a difference: 27.1V instead of 28.4V with the backlight OFF.
                                          • Asraf Atb
                                            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                            by Asraf Atb
                                            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                            01-27-2025, 05:02 PM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • alltvrepairs
                                            Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
                                            by alltvrepairs
                                            I have confirmed that I have a mainboard problem.
                                            I have tracked no hardware issued on board so might be a software dump required.
                                            I have searched a bit but wasn't able to find anything for my screen:
                                            Here are some more details:
                                            Panel: cy-nn065hgev1h
                                            Main: BN94-14180M P08F
                                            Your help much appreciated!
                                            05-16-2025, 03:03 AM
                                          • ygorsan
                                            by ygorsan
                                            🧩 Problem Summary:
                                            • I
                                            07-28-2025, 08:34 AM
                                          • Lee M.
                                            Samsung UN75RU8000FXZA bad main board?
                                            by Lee M.
                                            When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                                            11-08-2023, 07:46 PM
