T-con T400HW01 V4 repair
  • jbfr_54
    • Dec 2012
    • 52
    • France
    Hi, I have a 40" Samsung TV with this card. Very solarized image. Willing to replace AS15-F chip but I have only a HX8915 available chip that looks similar.does anyone knows if they are equivalent or has the datasheet of the HX8915 ?
    Thanks to all.
    Jean
    Re: T-con T400HW01 V4 repair
    AS15-F is all over eBay. I would not chance it unless you absolutely knew it would work.
    • borifrank
      Bori Frank
      • Dec 2013
      • 3
      • u.s.a.
      use this link
      http://www.ebay.com/itm/5pcs-AS15-G-...E:L:OU:US:1120
      Last edited by borifrank; 02-18-2014, 04:55 PM. Reason: compromise my pass wrd and account ...sorry
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • netgearnetgear
        TCL 43S423 TCON OR PANEL FAULTY???
        by netgearnetgear
        Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
        08-20-2025, 06:04 PM
