Samsung plasma screen not centered
  • Dirtbikeguy2003
    • Dec 2013
    • 20
    • Usa
    My plasma screen is shifted to the right about 8 to 10 inches. Is there any way to adjust this. Model number pn43d450. It's the same on all the different inputs and players.
    Re: Samsung plasma screen not centered
    Are the menus also shifted?
    • Dirtbikeguy2003
      • Dec 2013
      • 20
      • Usa
      Everything. The USB screen is also shifted.
        OK, did this occur suddenly, or did it slowly drift?
        Try the following:
        1. Put the TV into standby using the remote control
        2. On the remote quickly in sequence press: MUTE, 1, 8, 2, POWER.
        3. After about 15 seconds TV powers up in service mode. Is service menu visible?
        4. If menu is visible, locate the reset option and select it (press OK.) Do not touch anything else. If in any doubt, please consult here first.
        This will put TV back to absolute shipping settings and reset any custom settings, calibration, user data, tuning, etc. It will be like out-of-the-box.
        • Dirtbikeguy2003
          • Dec 2013
          • 20
          • Usa
          The tv had a bad main board and I replaced it. I think it's has this alignment problem since it was new. I did a factory reset and it's still shifted to the right.
          • Dirtbikeguy2003
            • Dec 2013
            • 20
            • Usa
            Here is a picture.
              Oh, did you happen to use main board from 51" in your 43"? The 51" is 1366x768 pixels or thereabouts. The 43" is 1024x768. The main boards are different and not compatible.
              What options do you have on the service mode?
              • Dirtbikeguy2003
                • Dec 2013
                • 20
                • Usa
                I don't think I did. I this one from eBay.
                Samsung PN43D430, PN43D450 BN96-19469A, BN41-01608A Main Board
                • mmartell
                  • Oct 2013
                  • 3189
                  Try the service menu as tom suggests. It's not out of the realm of possibility that a PO set it wrong in the service menu then parted the set out and the board wound up in your hands.
                  • Dirtbikeguy2003
                    • Dec 2013
                    • 20
                    • Usa
                    How do I adjust it in the service menu.
                      Can you post a picture of the options available on the service menu?
                      • Dirtbikeguy2003
                        • Dec 2013
                        • 20
                        • Usa
                        Here is the main screen.
                        • Dirtbikeguy2003
                          • Dec 2013
                          • 20
                          • Usa
                          I have went through the menu and did not see any type of horizontal adjustment
                            OK, show us what's available under OPTION and CONTROL.
                            There won't be a simple adjust, you just have to find where to set panel from 51" to 43", may not always be available though.
                            • Dirtbikeguy2003
                              • Dec 2013
                              • 20
                              • Usa
                              Here is the options picture.
                              • Dirtbikeguy2003
                                • Dec 2013
                                • 20
                                • Usa
                                Here
                                • Dirtbikeguy2003
                                  • Dec 2013
                                  • 20
                                  • Usa
                                  Here is control window
                                  • Dirtbikeguy2003
                                    • Dec 2013
                                    • 20
                                    • Usa
                                    I see under OPTION there is a TYPE option and it's 51dhhcd
                                    • Dirtbikeguy2003
                                      • Dec 2013
                                      • 20
                                      • Usa
                                      If I select it there is no other options for that type
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Sounds like it may be as tom suspected. Snap a pic of that screen it may be useful when returning the board should you have to.
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • Kiberge
                                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                                          by Kiberge
                                          HI guys!
                                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                          04-22-2024, 11:28 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • kotel studios
                                          Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                                          by kotel studios
                                          Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                                          In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                                          Yesterday, 02:07 AM
