ps50c96hd ysus repair
  • wreksta
    • Aug 2013
    • 508
    • england
    hi all im busy repairing this board
    tv clicks when its connected but no green protection light shows
    anyways
    im trying to find out all good values of mosfets under heatsinks
    heres a picture thiese measurements were made in diode mode don't know if that's good or bad
    also the zd5502 I can test this but continuity makes a beep on my meter is it supposed to ?
    please help as much as you can as ive been on this board all day its got me at me wits end
  • wreksta
    • Aug 2013
    • 508
    • england
    Re: ps50c96hd ysus repair
    ok I think I tested thes all wrong I used 20k in ohms mode on my multi meter and all except 4 mosftes show 9.96 the four remaining show 0.14 these I suspect to be bad
    • wreksta
      • Aug 2013
      • 508
      • england
      anyone lol and wil using a ba1 buffer set be ok or not
      • PlasMatt
        LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
        by PlasMatt
        I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
        09-20-2025, 06:50 PM
      • chth96
        by chth96
        03-09-2024, 10:03 PM
        12-31-2023, 06:04 AM
      • Ryan Wurtz
        Lenovo Yoga C740-15IML 5V on usb meter.
        by Ryan Wurtz
        Hello. So I searched and didn't find any posts on this specific problem.
        When plugged in USB power meter reads 5v
        Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
        Original mobo had a shorted cpu it seems.
        So I decided I need a new motherboard.
        Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
        5v on the meter. Still won't charge. Can still charge the battery...
        Yesterday, 01:08 AM
      • jorpec
        by jorpec
        Hi
        Thnaks
        01-23-2023, 10:37 AM
