52"RCA Problem.
+ More Options
Posts
  • wadenvk
    • Nov 2011
    • 55
    Re: 52"RCA Problem.
    Here are some pictures could not get the whole strip in there.
    • johnboy1313
      • Nov 2012
      • 1959
      Re: 52"RCA Problem.
      Wow. I have no idea. At this point, I'm honestly guessing. On the left of the picture of the LED side of the strip, there are two test points labeled + and -. In between all of the other LEDs is a test point. I'm thinking that they are all +. There are also five pins at the connector and ten LEDs on each strip. I would guess that each pin is connected to a pair of LEDs. They are likely all connected to a common ground. I would start by checking for continuity between the five pins when the strip is unplugged and when it is plugged in. I would also check for continuity between each of the pins and each of the test points. Finally I would set my meter to diode mode and put the red lead on a test point and the black lead on the - test point, then swap the leads and check them all again.
      • johnboy1313
        • Nov 2012
        • 1959
        Re: 52"RCA Problem.
        Also, in this pic
        https://www.badcaps.net/forum/attach...8&d=1386285536
        It looks like there is writing between the 2nd and 3rd LEDs and the 5th and 6th LEDs (starting from the center of the panel). Could you post pictures of the writing?
        • johnboy1313
          • Nov 2012
          • 1959
          Re: 52"RCA Problem.
          Another thought that I just had is that you may be able to unplug the two bad strips altogether and get the set to power on. If that works maybe you could swap the good ones around so that the top strip on one side and the bottom strip on the other are missing. It would obviously be a little dimmer at those points but maybe not enough to be a deal breaker.
          • wadenvk
            • Nov 2011
            • 55
            Re: 52"RCA Problem.
            Alright I have tested the two strips that are not lighting up and found nothing wrong with them, I switched them out with known good strips and they do flash so I may have to head back to the supply.
            • johnboy1313
              • Nov 2012
              • 1959
              Re: 52"RCA Problem.
              You put a strip that would flash in the spot of one that wouldn't flash and it then didn't flash? I suspect that the PSU is good. You may want to check the wiring.
              • wadenvk
                • Nov 2011
                • 55
                Re: 52"RCA Problem.
                Alright I have tested this down to one strip that has different voltages. I was able to order all new strips but wondering if there is a way to find out what the voltage should be coming in to the strips from the board. right now I have 178v at the plug and at the start of the strip and gets lower as I light each led. The 178v take's care of two strips.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  Re: 52"RCA Problem.
                  178v for twenty LEDs seems high. I've been wrong before though. Unplug con5 and con6, power the set on, and take readings from the + pins on those connectors.
                  • wadenvk
                    • Nov 2011
                    • 55
                    Re: 52"RCA Problem.
                    Sorry was on wrong setting the dc voltage is 81.6 at the pin on con5 and 6 + and it is 81.6 at each led strip.
                    • wadenvk
                      • Nov 2011
                      • 55
                      Re: 52"RCA Problem.
                      Should that voltage jump around when powering up? With my test leads in place and powering it up voltage jumps to 160vdc then drops to 81.6.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        Re: 52"RCA Problem.
                        I wouldn't expect that much of a spike. It's possible that your meter is just thinking a bit before it gives an accurate reading.
                        • wadenvk
                          • Nov 2011
                          • 55
                          Re: 52"RCA Problem.
                          Thanks waiting on the new led strips. the one strip that i have narrowed it down to when just that one is plugged in there is no flash but constant power there 81.6vdc and i can test each led they all work in series but when i get to 19 and 20 led there is not enough power left to light them up. weird.
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            Re: 52"RCA Problem.
                            I don't follow your last comment. There are 10 LEDs on each strip, correct? Which LEDs are you calling 19 and 20? I'm thinking you may be able to substitute a resistor of some value in place of the two bad LEDs but I'm so far removed from an electronics course that I don't remember everything I've learned about LEDs. I keep bringing this thread back to the top hoping someone with more knowledge will step in and help you out.
                            • wadenvk
                              • Nov 2011
                              • 55
                              Re: 52"RCA Problem.
                              They are hooked up in series so two strips will power up at once, With the two strips are powered up there is no flash and I can read power on all 20 leds when I check down the line of leds when I get to the last two there is not enough power to light the last two up.
                              The new leds should be here today will put them in and see what happens. I will figure it out one way or another. Thank again for pointing me in the right direction.
                              • wadenvk
                                • Nov 2011
                                • 55
                                Re: 52"RCA Problem.
                                Thank you johnboy1313 the tv is working great 26 bucks for the new leds and that was all it needed. thanks for leading me there.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  Re: 52"RCA Problem.
                                  AWESOME!!!!!!! 26 well spent bucks.
                                  • django7975
                                    • Apr 2014
                                    Re: 52"RCA Problem.
                                    Hello, If anyone is still watching this thread i have a similar problem with the identical model. I have followed the instructions in the thread and managed to confirm all of my led's will burn. I can unplug com5 and com 6 and get the big cap to read 380V. When i jump the led from negative to positive all the lights come on on the positive led's but i have to use the positive led lead to get the negative led strips to come on. I really don't know how to proceed from here. Thank you.
                                    • jeremy1976
                                      • Apr 2017
                                      • 10
                                      Re: 52"RCA Problem.
                                      Where did you buy the LED strips? and how are they replaced? all on one board or in strips? Thanks have same issue
                                      • madlee357
                                        • Jul 2014
                                        • 6
                                        • florida
                                        #59
                                        Re: 52"RCA Problem.
                                        Check the main capicatior
                                        • toti24
                                          (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
                                          by toti24
                                          dell precision m4600 laptop
                                          i7 2760qm
                                          8gb ram 750gb HDD
                                          intel hd 3000 integraded and nvidia quadro 2000m
                                          pleasea bear with me english isnt my language and ill try to be as clear as possible
                                          note i live in mexico in a very small town..
                                          thank you.
                                          laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
                                          the brick happened when i was installing win 10 using usb.
                                          used rufus and officia microsoft.iso
                                          it finished copying files from usb...
                                          03-06-2022, 08:39 PM
                                        • corrize
                                          Nikon D800 camera - flash don’t work and capacitor don’t charge
                                          by corrize
                                          Hello, I'm stuck in troubleshooting…
                                          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                          10-01-2022, 10:02 AM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
