Samsung PN50A450 - No Power
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Samsung PN50A450 - No Power
    Can you just check on your PSU for a code... starts BN44
    Just want to check we have the right service manual
    • steveh_131
      • Nov 2013
      • 33
      I did did check on that and it is the right one. I looked at the pdf posted earlier.
      • newtothis
        • Mar 2013
        • 1556
        • england
        Ok yes unplug from maniboard side - CN801
        Jumper pin 6 and 7 on connector CN807
        Jumper pin 9 and 10 on connector CN807
        Unplug LVDS cable
        Turn tv on
        • steveh_131
          • Nov 2013
          • 33
          Excellent. Should I leave CN807 connected while I jumped them?
          • newtothis
            • Mar 2013
            • 1556
            • england
            Yes
              Pins 3-4 on logic board need to be jumped to get test patterns -- https://www.badcaps.net/forum/showpos...61&postcount=2
              • newtothis
                • Mar 2013
                • 1556
                • england
                #27
                Oh yeah sorry that too.
                https://www.badcaps.net/forum/showpo...61&postcount=2
                • steveh_131
                  • Nov 2013
                  • 33
                  LVDS is unplugged.
                  Power supply to main board is unplugged at main board.
                  Jumpered from 3-4 on pins on control board.
                  Jumpered 6-7 and 9-10 on CN807.
                  Tried to turn on and didn't do anything.
                  Noticed that pin 6 is RTN, not GND as Tom mentioned...so I jumped pin 7 to the ground and the tv turned on. It's flashing white red and green and purple, etc. now.
                  Is this a clue?
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    #29
                    Originally posted by steveh_131
                    LVDS is unplugged.
                    Is this a clue?
                    Oops sorry about the RTN, error on my part.
                    Mainboard is at fault then
                    Main board diagnostics are beyond me at the moment, I would simply replace it.
                    • steveh_131
                      • Nov 2013
                      • 33
                      Very cool, thank you!
                      Maybe this is a dumb question, but if I jumped the PWR_ON like that while it was all plugged in, would that make it work?
                      Steve
                        Unfortunately not: the main board is simply not turning on the signal because it is stuck in some kind of fault mode. If you did that you would be left with a slightly glowing black screen with no image. The fact that you got test patterns means the fault is with the main board.
                        • steveh_131
                          • Nov 2013
                          • 33
                          Ok, you guys are awesome.
                          Last question:
                          I found this on ebay: http://www.ebay.com/itm/Samsung-BN94...50A450P1DXZA-/
                          I can't find a part number on the main board that matches anything on ebay for this model. It has several stickers with with different part numbers.
                          How do I tell if this eBay board will match my unit?
                            See this video:
                            http://www.youtube.com/watch?v=R1jmj_foId0
                            • steveh_131
                              • Nov 2013
                              • 33
                              Thank you, fellas.
                              I ordered a replacement board on ebay. I will replace it next week when it comes in, and I plan to update this thread with the results for the future use of anyone else with the same problem.
                              This was very educational and I appreciate all of the input.
                              Steve
                              • newtothis
                                • Mar 2013
                                • 1556
                                • england
                                #35
                                Your welcome.
                                Look forward to hearing the results
                                • steveh_131
                                  • Nov 2013
                                  • 33
                                  Installed the new main board today.
                                  Fired right up with no problem!
                                  This turned out to be a heck of a good deal. Thank you all for your help. I'm soldering a few new capacitors into a Viewsonic sometime this week, so I'm sure you'll be hearing more from me as I venture into even more unknown territory.
                                  Take care!
                                  • aaronwt6
                                    • Apr 2013
                                    • 855
                                    • US
                                    #37
                                    Not to dig up an old thread but I wanted to give thanks as always to newtothis and tom66. Got one of these TVs on the bench right now and followed this thread to determine that the control board was faulty. Not sure why more TVs don't have a test mode like this. Sure does make sense.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      Aaron, what's the number of the control board? I have a PN50B450 and a C450. If you need the board and I have it, I'll give you a good price.
                                      • aaronwt6
                                        • Apr 2013
                                        • 855
                                        • US
                                        #39
                                        Thanks for the offer but I already had one on order when I wrote this.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • mrtek
                                          Samsung UN43NU6950FXZA No power
                                          by mrtek
                                          Hi
                                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                          Main fuse = OK
                                          Back light LED = OK. Power them with aux power source
                                          LED output = OK 156V
                                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                          07-20-2025, 08:06 PM
                                        • hill01
                                          Samsung UE75MU7009TXZG Endless Power Cycle
                                          by hill01
                                          Hi everyone and thanks in advance for any help I might get here
                                          My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                                          About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                                          Since a few days, the TV won't turn...
                                          11-17-2021, 02:52 PM
