vestel 17IPS06-2 help
  • Sparks88
    • Sep 2011
    • 110
    I need the schematic for a vestel board 17IPS06-2 290108 which has main board 17MB35-4 060109 any help appreciated, the main board on mine is slightly different to others i have seen in that it has a cap 22uf 6v by the top 5 pin connector (used for programming) and 3 hdmi sockets, i am getting the infamous 2 seconds to black, checked all voltages and the only thing on the power board (nearest schematic i could find) is the 5v standby is low at 4v, everything elas seems to be within .5v of spec, andbody who has experience of this board please feel free to add a comment or 2, thanks in advance
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: vestel 17IPS06-2 help
    No doubt Tom has come across these boards!
    • Sparks88
      • Sep 2011
      • 110
      the power board is 290708 and not as i wrote above, there are 2 caps where normally you would find a large 400v type and the voltage across the pos leg is approx 230v dc and it doesnt change when the set is switched on and only changes by 3-4 volts
        Have seen one in a 24" Technika. Caused by one of the inverter transformers failing open. Common fault.
        • Sparks88
          • Sep 2011
          • 110
          thanks tom, will check and let you know.
          • Sparks88
            • Sep 2011
            • 110
            spot on, tr701 o/c, dont suppose you know where i can get a IVE8001CL transformer from in the uk?
            • newtothis
              • Mar 2013
              • 1556
              • england
              Can only find overseas... ~£18 inc shipping
              • Sparks88
                • Sep 2011
                • 110
                thats more than the sets worth considering the probable faults that will occur in the future, oh well time to start looking for a scrap panel on the fleabay (got one its mine) thank you for all your great help.
                  I've only ever found them from that location in Spain. I regularly sell 26" ish and 24" Full HD sets around £80 to £100 here, no problems. Hardly think a £20 investment is a waste.
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    Yeah I was thinking the same to be honest, I sell a lot of 22" monitors and get around £60 - £70 so for a bigger set it's worth it
                    • Sparks88
                      • Sep 2011
                      • 110
                      i didnt think it was worth it but maybe you are right.
                      • Sparks88
                        • Sep 2011
                        • 110
                        absolutely crazy postage prices from spain
                        • Sparks88
                          • Sep 2011
                          • 110
                          Right followup, got the new tranny but still the same problem, any more pointers, i will do a few more voltage check but getting the right manual is a nightmare.
                            Still test open? Or now about ~700 ohms?
                            • Sparks88
                              • Sep 2011
                              • 110
                              hi, both trannys measure 674 ohms in circuit
                                OK, do you get any backlight, even just a brief one?
                                • Sparks88
                                  • Sep 2011
                                  • 110
                                  yes after a few seconds the backlight flashes then goes to black
                                    Check all bulb connectors, no bent pins?
                                    Do you happen to have a neon bulb?
                                    This can be used to see if any of the transformers are not working.
                                    • Sparks88
                                      • Sep 2011
                                      • 110
                                      dont have a neon bulb is there any other way?
                                        Not that I'm aware of, but I can find neon bulbs on ebay for a few pounds each.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          Yesterday, 05:17 PM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
