Element ELCHW321 Catastrophic Failure
    Re: Element ELCHW321 Catastrophic Failure
    Check the DC voltage on that C841, C844, Gate voltage of MOSFET V812 (this voltage should toggle when TV is turned on and off).
    BTW, if you flex the board, does it make the difference?
    • mmartell
      • Oct 2013
      • 3189
      I've tried pushing on the board while in place and it made no difference.
      Will check those voltages.
      • mmartell
        • Oct 2013
        • 3189
        bud I rechecked and have a good 12v supply. The 5v supply is at 1.35v so I checked at V813 and (if I have the pins right...) have
        G=12.4v
        D=5v
        S=1.35v
        Does that mean the mosfet is bad ?
          G=12.4v
          D=5v
          S=1.35v
          That cannot be right, to get 12V output at the S pin of the MOSFET V812, the D should have more than 12V, that D pin is connected to the power supply that has filter cap C844 (1000UF 25V) which is the one that provides 12V power for the MOSFET. See SCH.
          "bud I rechecked and have a good 12v supply" Which 12V is that in the diagram? Since S pin only shows 1.35V how do you get good 12V OK?
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #45
            buds mentioning v812 your are testing v813? just to comfirm
            • mmartell
              • Oct 2013
              • 3189
              That is correct vince, I am testing V813 as my 5v rail is low. I assume all is good with V812 as I have 12v supply at the connector (output to main board)
                Yes, I am asking about V812 since post 41, it is the MOSFET for switched power supply which you had indicated that you do not have either switched 12V or switched 5V. The switched 5V which is supplied by MOSFET V813, it is turn on when switch 12V is turn on, then that 12V output is used to bias on V813.
                So you are telling me now that the switched 12V is working but the switched 5V is only putting out 1.35V?
                It is really confusing now since all along I thought you do not have either switched 12v or switched 5V.
                • mmartell
                  • Oct 2013
                  • 3189
                  I do apologize bud, you have it correct. Switched 12v line is outputting 12.4v and is also seen at the gate of V813. However its output is only 1.35v
                  Should I remove the 5v supply pins from the connector to see if the main board is pulling down the supply or should I replace the mosfet V813 ?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #49
                    i only noticed after reading the whole thread theres some good fault finding tests as im still learning reading these sort of threads helps me to understand the psu a little more as budm explaines it so its easy to understand i hope you manage to fix the psu.
                      OK, now I understand, so you have only 1.35V instead of 5V, since the Gate is getting enough voltage o bias on V813 then it may mean that the MOSFET is bad, or too much load is on that switched 5V output. Does the V813 get very hot? If not then it can be just bad MOSFET. You can disconnect that switched 5V out put wire and use 10 Ohms (or 15 Ohms) 5W to simulate the load and see if the output will stay at 5V (the power supply is rated at 5V 0.5A).
                      • mmartell
                        • Oct 2013
                        • 3189
                        Thanks bud, will report back later.
                        • mmartell
                          • Oct 2013
                          • 3189
                          Pulled the pins and have 5.18v at the connector. I don't believe I have a resistor of that size to test with dummy load as you suggest but will have a look soon.
                            You can use combination of resistors connected in series or parallel just to get close enough to 10 Ohms ~5W. What do you have?
                            • mmartell
                              • Oct 2013
                              • 3189
                              Nothing loose I will have to look over some boards that are buried around here.
                              • mmartell
                                • Oct 2013
                                • 3189
                                I have a mind to change out the mosfet only because the seller said it wouldn't power up his tv either. So either the mosfet failed or he had a similar problem with his main board that I might have with mine. Chances are...
                                  You can take a chance by setting your meter in DC AMP mode, then put the probes on the S and D pin so it will show the current draw on that switched 5V output, I would suggest soldering the wires to the board and attach them to the meter because I do not want to take chance of slipping probes.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    In parallel with the mosfet itself ? I thought the probes had to be in series to measure current.
                                      The meter will basically bypass the MOSFET, you will connect the meter AFTER the 12V is on.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Ok so pull the probe and put it in Amp spot on meter. Set range to Amperes. Turn on tv and fix probes to S and D. Is it ok to put one probe on S or D and touch the other after power up ?
                                        • mmartell
                                          • Oct 2013
                                          • 3189
                                          That IS the proper way, right ?
                                          • npielawski
                                            MacBook Pro late 2016 (820-00239) with multiple failure modes.
                                            by npielawski
                                            I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                                            I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                                            10-15-2025, 01:53 AM
                                          • flysky
                                            Gigabyte H610M S2H V2 help to identify the element.
                                            by flysky
                                            There is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
                                            Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.​
                                            01-23-2025, 07:21 PM
                                          • EasyGoing1
                                            The best way to drive a heating element?
                                            by EasyGoing1
                                            I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                                            What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                                            This is the general setup that I have now.
                                            This is what the...
                                            01-25-2023, 11:29 AM
                                            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                            12-16-2023, 08:39 PM
                                            Surface Mount Fuses Fundamentals Datasheet
                                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                            10-07-2024, 06:07 AM
