ChiMei M270H1 T-con repair
    I have this 27" FHD LED-LCD screen from an Acer LED-LCD TV to repair. My second LED TV. Let's hope it's not another bad panel . Fault is the picture is jumpy, unstable, etc. with random (but non static) lines. Some slight (<0.5sec) image retention. No black bars or anything, just unstable picture. I don't see any shorts to ground on the VGL, either. About 20kohm one way, 40kohm the other.
    I found some burn damage to the t-con on the part which generates VGL (-5V to -10V normally, I believe it to be approx -7.5V on this panel.) The t-con is permanently mounted to the panel, so can't be replaced unfortunately.
    I traced out a part of the circuit, as best I could.
    Anyone with a cracked screen panel like this who could read off voltages?
    Re: ChiMei M270H1 T-con repair
    Picture of burnt diode.
      I tried this ugly bodge... and...
      It lives! Those are 1N4148 diodes replacing the dual series diode that I reverse engineered (the diode was totally destroyed and unreadable, but I figure the charge pump circuit couldn't work any other way.)
      I am quite surprised myself, was half expecting panel to be bad!
      LED TVs & monitors: 2-1 to me.
      BTW, this ACER gets a repairability score of negative 5 out of 10. It is so awfully put together. The main board and power board are mounted to the back plastic and the wires are so short, there's barely any space for testing or unplugging cables.
      • mmartell
        • Oct 2013
        • 3189
        geez nice save, tom. How DO those three legged diodes work anyway ?
          Basically two diodes in one. They come in several configurations. See below.
          In my case, it was the "BAR43S" type, which is the only type which could work in this application, though I'm not certain it was originally a BAR43S, it would still work. (Dropped voltages would be ~0.3V each with a BAR-type Schottky diode; I used silicon, but as can be seen below, the difference would not matter, as the -14.6V is regulated immediately.)
          It's a negative charge pump. It converts a positive AC square wave into negative DC. It has several states.
          • At t=0, let's say switch node is at 16V. Cap C18 charges 16V thru D2 3-2. (Minus ~0.7V drop from diode.)
          • Then lets say after some finite time t that switch node drops to 0V.
          • Cap C18 still has 16V across it (because it can't discharge due to the diodes), but one end is at 0V, therefore other end must be at -16V.
          • The diode D2 3-1 transfers this charge on to C20. (Hence name "charge pump". Charge is pumped between two capacitors to create the desired effect.) Minus another 0.7V drop.
          • Total output voltage after many cycles = Vsw - 1.4V = -14.6V assuming minimal load.
          This -14.6V is then regulated by the transistor-zener circuit to around -7.5V.
          • mmartell
            • Oct 2013
            • 3189
            I've always suspected but now I KNOW I'm a little like that guy from A Beautiful Mind because when you talk like that the logic makes me want to cry. Lol I'm just a little too ignorant as of yet to fully understand it.
            Seriously, how did you know to expect a positive square sine wave at that point or did you recognize a charge pump configuration first and deduce the latter ?
              I could recognise the topology of a boost converter (that produces that square wave), plus basically every LCD panel out there uses the same standard design.
              The boost converter produces the 16V for the AVDD, which the LCD panel uses about 1 amp from. The other rails, VGL and VGH, require approximately 20mA each. Since their current draw is so minimal, they lend themselves well to a charge pump design (the cost of two caps and a dual diode: <10 cents in bulk volumes. Cost of a dedicated switching converter: ~$1)
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • advant
                by advant
                02-03-2020, 12:25 AM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
              • netgearnetgear
                TCL 43S423 TCON OR PANEL FAULTY???
                by netgearnetgear
                Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                Yesterday, 06:04 PM
              • Daren87
                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                by Daren87
                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                08-13-2023, 03:25 PM
