Philips 42PFL5522D/05 Blown Caps
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 209
    hi guys ive got the above tv
    and it had 5 blown caps on the psu board
    I replaced 3 with the exact same voltage 450V but instead of them having 68Uf I used 100Uf ones will they hurt anything ??
    I also replaced 2 caps that was 25v 1500uf with 35v 1000uf caps again im worried if they will hurt anything ??
    as the tv is working perfectly I have ordered the correct ones to replace in the tv PSU but im wondering if it will damage anything ??
    thanks for any help I have also attached a pic marking where the damaged caps was
    cheers
    jason
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
    Re: Philips 42PFL5522D/05 Blown Caps
    In the mean time, it should be fine.
    • jasonr2000
      Advance Tech
      • Nov 2013
      • 209
      ok thanks tom66
      I had to ask as ive never worked on a tv PSU before
      but correct caps are on the way
      Samsung UE46D6530
      Samsung BD-F7500
      Samsung HT-ES6200
        What ones did you order?
        • jasonr2000
          Advance Tech
          • Nov 2013
          • 209
          I ordered the following ones
          3x 450v 68uf Nippon ones on ebay 251229997098
          and
          2x 25V 1500uf Nippon on ebay 111015210593
          Samsung UE46D6530
          Samsung BD-F7500
          Samsung HT-ES6200
            KXG is not a low ESR capacitor, so it might fail soon. The KY is though.
            • jasonr2000
              Advance Tech
              • Nov 2013
              • 209
              can u recommend some then tom66 ??
              as I dunno what caps are best
              thanks
              Samsung UE46D6530
              Samsung BD-F7500
              Samsung HT-ES6200
                My error. The 450V capacitors do not need to be low ESR, so both those are fine.
                • jasonr2000
                  Advance Tech
                  • Nov 2013
                  • 209
                  oh ok
                  that's cool saves me looking for others
                  can I ask u one more question
                  is it normal for the 450V caps to go bad ?
                  Samsung UE46D6530
                  Samsung BD-F7500
                  Samsung HT-ES6200
                    They rarely fail. Typical cause of them failing is excessive line voltage for a long time. In your case the line voltage would had to have exceeded 450V/sqrt(2) = 318V AC for a long time. Even if this had occurred other damage would have most likely occurred to other parts. They can fail due to poor PFC circuit design but that is quite rare. Do you have a picture of the failed capacitors?
                    • jasonr2000
                      Advance Tech
                      • Nov 2013
                      • 209
                      well I know when I took it off the wall after it went out I noticed that the PSU was full of dust and I mean really bad I dunno if that caused excessive heat build up and made them go bad
                      as all the heatsinks where black u couldn't see any silver at all
                      as I said I dunno if that will do it
                      and ill take a picture of the damaged ones for u 2 see and post it
                      Samsung UE46D6530
                      Samsung BD-F7500
                      Samsung HT-ES6200
                      • jasonr2000
                        Advance Tech
                        • Nov 2013
                        • 209
                        here they are its not the best shot as I don't have a proper camera
                        Samsung UE46D6530
                        Samsung BD-F7500
                        Samsung HT-ES6200
                          Are those the 450V ones? Definitely bad. Interesting. Luckily you caught that early. If they go bad too much then it can cause further damage to the power board.
                          • jasonr2000
                            Advance Tech
                            • Nov 2013
                            • 209
                            yeah they are the 450V ones
                            the 25V ones had popped the tops open all sanwha branded
                            I also noticed the 450v ones had leaked electrolytic over the board also
                            im just glad it didn't do further damage as the only psu I can find on ebay that's the same is £50
                            Samsung UE46D6530
                            Samsung BD-F7500
                            Samsung HT-ES6200
                              So out of interest what was it doing before you replaced them? Slow to turn on? Complete refusal to turn on?
                              • jasonr2000
                                Advance Tech
                                • Nov 2013
                                • 209
                                no power at all tom66
                                the power light didn't even come on
                                so I removed the rear cover and saw the caps was bad
                                replaced them with what I had to see if it still worked and it fired up with no issues
                                but want to put the correct ones back in there so it don't damage the psu
                                Samsung UE46D6530
                                Samsung BD-F7500
                                Samsung HT-ES6200
                                • odtech
                                  Asus UX490U laptop blown (caps?) on power board.
                                  by odtech
                                  Greetings friends.
                                  I was given this nice little laptop and would like to revive it if possible but i'm stuck identifying blown components. I'm very new to the repair game so i'm proceeding very cautiously.
                                  I don't know the history of this laptop and the donator didn't elaborate what happened but it seems some moisture got into the USB C charge port and the result was what looks like some blown caps. The tell is some gunk inside the USB C port and corrosion on the outside as well as what looks like corrosion around the blown components.
                                  Any guidance...
                                  08-06-2023, 10:29 AM
                                • aidanmo
                                  Philips 43PUS7506/12 - Loud blown out sound
                                  by aidanmo
                                  I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                  I thought maybe the speakers got damaged, so I replaced them - no dice.
                                  • Using the internal speakers, it always happens.
                                  • Using the headphone jack, it never happens.
                                  • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                  02-28-2025, 03:13 PM
                                • zlr8r
                                  HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
                                  by zlr8r
                                  Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
                                  To begin with, this laptop was dead-dead.
                                  Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
                                  • am getting white power led
                                  • 5-long-flashes on CAPS Lock and NUM lock
                                  • then, fan full speed
                                  • CPU heats up some (smaller die PCH, does not)
                                  • always constant black screen no matter what's tried
                                  • no USB recognition
                                  • no HDMI output
                                  this is as far as I can get with it and not sure where to inspect next ?
                                  I tried...
                                  03-27-2024, 03:13 PM
                                • eryjus
                                  by eryjus
                                  05-10-2023, 11:21 AM
                                • whc14765
                                  1070 - Blown SMD caps, short on 12V PCI
                                  by whc14765
                                  Hey
                                  I got a short on 3 pins of the PCI-E gold connector for 12V.
                                  I see a few caps near the top right (near main power connector) that look blown, one is showing a short across it to GND.
                                  Unforunately I don't have a schematic or board view for it (EVGA GTX 1070 FTW 8GB).
                                  Due to the large number of caps there, I think it may just be decoupling.
                                  Any ideas on figuring out the cap values? There also isn't any reference numbers for the caps on the silkscreen.
                                  11-23-2022, 06:42 PM
