LG 37LF65-ZC No Backlight
    Re: LG 37LF65-ZC No Backlight
    What is the part # of your inverter? Most inverters can be substituted easily enough.
    • Daveatfernie
      • Nov 2013
      • 70
      This links to my inverter http://flattvparts.co.uk/index.php?m...rd=6632L-0480A
      Cheers
      Dave
        I used a *504 inverter in place of a *490 inverter. You may be able to do the same. The 504 inverter is available for around £15 from here.
        http://www.ioffer.com/i/lg-philips-l...504a-517214946
        No guarantees but it worked perfect in mine. Even the metal shield fit perfectly over it.
        • Daveatfernie
          • Nov 2013
          • 70
          Inverter arrived today, fitted and didn't work.
          However took the previous post's advice and tried disconnecting the cable from the TCon board and it jumped to life.
          One working TV.
          Currently have a very big smile.
          I'll investigate the TCon cable to see if it is just an incompatibility or whether, due to the connector being in a different location I just haven't seated it correctlly.
          Thanks everyone for looking at my thread, for offering advice and helping me save another TV from land fill. I'll no doubt be back for more help with more TV's but I'm glad to have found this site.
          • ttmi100x
            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
            by ttmi100x
            Greetings everyone,
            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
            Upon closer inspection...
            07-31-2024, 06:36 PM
          • signal.quest
            Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
            by signal.quest
            I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
            I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
            09-30-2024, 11:21 PM
          • x_orange90_x
            by x_orange90_x
            01-29-2025, 09:24 PM
          • EvazX
            ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
            by EvazX
            I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
            Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
            For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
            However, after some time, the replacement motherboard...
            08-25-2025, 06:09 PM
          • lostone
            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
            by lostone
            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
            05-19-2024, 11:40 AM
