Maxent MX50X3 [P500550HM8] 50" Plasma - Vertical bands of noise
  • bobbworth
    • Nov 2013
    • 7
    Wow, wonderful community here! I'm hopeful one of the extremely gracious souls who frequent it can help me keep our family's 7year old Maxent plasma running. I've searched through past threads here for a couple hours, but haven't found precisely the issue I'm seeing and so am prevailing on the charity and knowledge of those who have helped so many others.
    So, the rundown:
    I purchased this set in Jan '06 and have recently had an issue with the display. The first sign of trouble was several months ago: The image on screen would flicker a few times from cold power-on before recovering and then remaining clear. That behavior persisted until last night when after being on for ~50 minutes we suddenly started seeing vertical bands of noise across the whole display. (See attached photos.)
    This noise will start after the set warms up with a few dozen pixels going wonky across the whole display and within seconds progress to what you see in the photos, sometimes with more or less noise. It is a pretty consistent pattern once it appears, though it sometimes disappears entirely for brief periods (a minute or two at most).
    Another clue to whatever the issue is: If I "tug" on the set (wall-mounted) the noise will sometimes disappear entirely. Alternately, it will sometimes increase in proportion to how much I move the set.
    The noise does cover the OSD. It appears on all inputs, but only while searching for and displaying a signal. If no signal is detected after a couple seconds, the set displays a clear blue screen.
    My ultimate question is: "Can I fix this myself reliably for less than ~$600?" I do not have the luxury of tinkering endlessly, and don't have the skills or tools to solder, but I am capable of re-seating cables or purchasing/replacing a board if there's a high probability of success.
    Thank you for any insight!
    Bob
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Maxent MX50X3 [P500550HM8] 50" Plasma - Vertical bands of noise
    yes if you remove the back cover not the hole cover but the that small cover covering up the mainboard for all the input connections you will see an IC with a green heatsink on it it'll be the hottest of all of them push on that heat sink and see if it goes away if it does you have a bad solder connections between that I see in the board itself this is a known problem with this model.
      Pictures of the chassis will help - this will most likely use an LG or Samsung panel and could have a control board defect, usually cheap to fix.
      • capkid
        • Oct 2010
        • 1339
        It appears that either the logic control board or the main board is faulty. You could try cleaning the cable connections with electronic contact cleaner. The logic boards are usually around $20 if you want take a gamble.
        Does the TV flicker if it's left with the blue screen displaying?
        LG Plasma Mal-Discharge Correction Service
        • bobbworth
          • Nov 2013
          • 7
          Wow, thank you all for the incredibly quick replies!
          @tom66: Would a pic of the mainboard suffice? Or should I pull the whole big cover off and get pics of everything?
          @freakaftr8: I've taken the set off the wall and put it on its stand to be able to access the back while its on. After being on for 30+ minutes.... no noise. So, I tried using a hair-dryer directed at the IC's heatsink, and still nothing. I'll leave the set on and continue checking it tonight and report back.
          @capkid: No flickering or noise if it's showing blue screen with no signal. Yes noise if it's blue screen while searching for signal.
          • capkid
            • Oct 2010
            • 1339
            A pic of the whole back of the TV would be best.
            • bobbworth
              • Nov 2013
              • 7
              @freakaftr8: Alright, I've started seeing noise again, and yes, I can confirm that pressing with moderate force on the square green heatsink causes the noise onscreen to disappear. Sidenote: I removed the frame that the mainboard is attached to so I could get a picture of the board underneath it., and now that I'm seeing noise again, it's no longer vertical but instead horizontal blue lines.
              @capkid: Photos of the whole unit and the mainboard specifically are attached. I have close-ups of the other components too if it would help to have a clearer look at any one in particular.
              I gather then that the mainboard is the issue. I see full boards available starting at ~$90 and going as high as ~$300. I also see a repair kit for ~$20. What's my best option: buy the whole board or buy the kit and find someone locally to assist with the repair? Or is there an option C?
              Thank you all again for your help and support!
              • capkid
                • Oct 2010
                • 1339
                I would say that it's best to have the board repaired, since this. is a common issue
                  I would focus on that RAM chip next to the green heatsink (surface mount no lead BGA), more likely that is the issue. Looks like EtronTech?
                  • bobbworth
                    • Nov 2013
                    • 7
                    Thank you both again for the speedy replies. I've only had time to follow up further today.
                    @tom66: You're spot-on. Yes, the module is manufactured by EtronTech. Where a moderate pressure on the heatsink corrects the issue, only the slightest touch to the RAM chip has an effect. From what I've seen you post elsewhere on this board, it sounds as though reballing a BGA is a delicate task – How do I go about getting this repaired?
                    • tony359
                      by tony359
                      11-28-2023, 05:18 AM
                    • MegaZAC
                      Onkyo TX-SR805 noise in one channel
                      by MegaZAC
                      Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                      Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                      There's some logic behind it. As soon as I select an input I get only left...
                      04-23-2025, 10:09 PM
                    • courtcircuit
                      Philips HTS8000 home cinema noise problem
                      by courtcircuit
                      Hello
                      I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                      Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                      Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                      I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                      Removed each of tyhe boards
                      02-08-2025, 08:22 AM
                    • roadrash
                      Old PC PSU making noise etc
                      by roadrash
                      A vintage 1980's PC power supply has started making a hissing and whining/squealing noise and the PC is now giving random errors like memory and video etc. Ive tried the PSU with just the Motherboard plugged in and its quiet but soon as I increase the load adding controller interface cards and drives etc, the noise starts. I think there is something about to fail but cannot see anything like a bulging cap or anything. Does anyone know whats the most likely suspect component? Here is a link to a video i took....
                      11-18-2025, 09:02 AM
                    • karatzdi
                      Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                      by karatzdi
                      I know some might say... just buy another one. Sell it as parts..!
                      So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                      Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                      Spent some time downloading the Service...
                      06-11-2024, 08:38 AM
