Insignia NS-50P650A11 clicks
  • blobula
    • Nov 2013
    • 16
    I don't have a lot of knowledge about how to diagnose the issue, but I'm certainly capable with direction.
    I see there was a similar thread, but I didn't see a resolution posted.
    I have an Insignia NS-50P650A11 that when I turn it on it trys to power on 3 times (3 clicks) then stops. I've been told it's a problem with the main power supply.
    I believe it to be this part here:
    Samsung BN44-00329B Power Supply Unit
    How should I test to ensure? Has anyone with this particular model experienced this problem?
    Thank you,
    blob
  • blobula
    • Nov 2013
    • 16
    Re: Insignia NS-50P650A11 clicks
    Here is some information very similar to my problem. Very well could be the same thing.
    Perhaps this may help someone else.
    http://www.justanswer.com/tv-repair/...unplugged.html
    • capkid
      • Oct 2010
      • 1339
      It's not impossible that the power supply (PSU) is bad, but it could very well be the Y-main or X-main that's faulty. The justanswer.com post doesn't show a definite resolution to the problem. I'd try disconnecting the X-main from the Y-main and the PSU first to see if the clicking stops. If it does, don't reconnect the X-main, as you risk damaging the Y-main.
      Edit: If you have a multimeter, you can check the VS and VA voltages that leave the power supply. Let us know if you need more detailed instructions.
      LG Plasma Mal-Discharge Correction Service
      • blobula
        • Nov 2013
        • 16
        Thanks for the response. Yes, I believe I'll need some additional instructions on this.
        So the Y-main is the board on the left attached to the PSU in the middle. The X-main is the board on the far right attached to the PSU.
        If I disconnect the X-main from the Y-main and PSU and the clicking stops what does that indicate to me? That the X-main is bad? If the clicking doesn't stop and I can't reconnect the X-main do I then disconnect the Y-main from the PSU?
        • capkid
          • Oct 2010
          • 1339
          (1) If the TV turns on with sound when you disconnect the X-main, you most likely have a faulty X-main. I'd replace the X-main and the tiny buffer board to the right of it.
          (2) If the TV does not turn on with sound when just the Y-main is connected, you most likely have bad Y-main and X-main. My recommendation at that point would be to replace the Y-main, Y-buffer (long board to the left), the X-main, and the X-buffer.
          A multimeter might useful to check the VS and VA voltages leaving the power supply. There should be a couple test points marked as "VS-TP" and "VA-TP". Also, the label on the back of the panel to the left of the X-main lists the voltage specs.
          Edit: If during your testing you find that your results match any of the scenarios I mentioned, I can show you how to quickly test a board's components to truly determine whether the board is bad.
          • blobula
            • Nov 2013
            • 16
            I disconnected the X-Main from the Y-Main and plugged it back in. I received the same results of three clicks and then nothing. The red light stayed illuminated afterwards on the front.
            Pic showing X-main disconnected from Y-main
            Should I disconnect the Y-Main now and try again? That would mean both X-main and Y-main are disconnected.
            I'll have to see if I can get my hands on a voltage meter tonight. When I got this tv the person I received it from said their testing showed the PSU was bad. However I don't know the results of that testing which led them to that conclusion.
            Thank you
            • capkid
              • Oct 2010
              • 1339
              Yes, I would disconnect the Y-main. The PSU in these TVs rarely fails, and I believe it goes into protection mode. This fools people into thinking that the PSU is faulty, since the output voltages drop, also.
              • blobula
                • Nov 2013
                • 16
                I disconnected the Y-main and plugged it back in. The tv seems to boot up. No clicking or anything. I don't have this hooked up to anything so I can't confirm sound, but the screen does not have picture.
                • capkid
                  • Oct 2010
                  • 1339
                  Yep, that's what I figured would happen. I'm almost certain that your PSU is fine. Ok, I'd recommend testing the X-main and Y-main components on the heat sinks with the two boards out of the TV to look for shorts. I'll post back with instructions in about 10 mins.
                  Edit: Testing the components will require a multimeter.
                  • capkid
                    • Oct 2010
                    • 1339
                    Ok, I've attached a pic of a Y-main from a similar TV. There should be a bunch of three-legged transistors and two-legged diodes on the Y-main's and the X-main's silver-colored large metal heat sinks. In diode mode on a multimeter, do the following:
                    Diodes: You're going to want to touch the red probe to one leg and touch the black probe to the other leg. Record the reading. Reverse the probes then record the reading. If any read 0.000, you have a short.
                    Transistors: The test is similar to the diode test, but you'll be alternating between combinations of the three legs. Again, if you see 0.000, you have a short.
                    Edit: If you find shorts, the board and it's buffer board should be replaced. These Y-mains and X-mains are not good candidates for component-level repair - trust me
                    • blobula
                      • Nov 2013
                      • 16
                      What is the secret to detaching the Y-main from these connectors? I don't want to break anything by applying to much pressure. Can the readings be taken with the board attached?
                      Looks like I'll have to take the readings tomorrow as the multimeter I borrowed seems to be broke. Goodness.
                      • capkid
                        • Oct 2010
                        • 1339
                        I slip a large flat-head screwdriver in the area pictured then I CAREFULLY twist it. I believe I also removed the board screws prior to doing so; it's been awhile since I last worked on one of these Insignias. You might be able to take the readings with the board attached, also.
                        • blobula
                          • Nov 2013
                          • 16
                          Awesome. Thanks so much for your guidance on this. I'll work on it tomorrow when I get a functioning meter and report back.
                          • capkid
                            • Oct 2010
                            • 1339
                            NP. I've subscribed to the thread, so I'll keep an eye out for your response.
                            • blobula
                              • Nov 2013
                              • 16
                              Ok I was able to get a working multimeter.
                              Multimeter being used and set to the appropriate settings per pic I believe.
                              I was able to get the board out without any issues. I started testing each diode from left to right at each screw location. (8 of them)
                              The transistor marked in your image gives me 0.000 when the probes are applied alternating. The diode as pictured in your image above gives me 0.000 with alternating probes applied. The other transistors and diodes give me a reading. Some are OL.
                              • capkid
                                • Oct 2010
                                • 1339
                                So, it looks like your Y-main is bad. Try the X-main, also.
                                • blobula
                                  • Nov 2013
                                  • 16
                                  I tested each diode and transistor on the x-main with alternating probes and none of theme went to 0.000 although one diode did get to 0.001.
                                  • capkid
                                    • Oct 2010
                                    • 1339
                                    That one diode on the X-main would concern me, and I'd declare the board bad. Ok, so it appears that you need to replace the Y-main, Y-buffer, and the X-main. The small board attached to the X-main is probably ok as-is, but you'll want to check some of the components in a similar fashion. Post a pic of the small board if you're unsure of how to test them.
                                    Regarding replacement boards, Shopjimmy.com is your best bet. They offer a 6-month warranty on their parts. Not including shipping, it would be around $85 for the Y-main, Y-buffer, and X-main. eBay has quite a few of the same parts for around $60 total. I'd personally spend the extra money for a little peace of mind.
                                    Edit: The Y-buffer may also be ok, but I've never found a reliable way to test those. If you don't replace it, you could fry your replacement Y-main and X-main.
                                    • blobula
                                      • Nov 2013
                                      • 16
                                      Thanks so much! If I start by replacing the Y-main and Y-buffer only and the tv works. Would I be in danger of harming those new boards as well if the X-main goes out later on?
                                      I'll take a look at that smaller board and order some parts.
                                      • blobula
                                        • Nov 2013
                                        • 16
                                        Just to verify these are the parts I'd need.
                                        http://www.shopjimmy.com/samsung-bn9...main-board.htm
                                        http://www.shopjimmy.com/samsung-bn9...main-board.htm (they say a firmware update is needing to be applied to help avoid having this part fail) You familiar with this?
                                        http://www.shopjimmy.com/samsung-lj9...scan-drive.htm
                                        • GRANDGG
                                          LG 42lw4500 flashing red light , wight light , 2 clicks
                                          by GRANDGG
                                          Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                          05-09-2025, 12:27 PM
                                        • cajoeg
                                          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                          by cajoeg
                                          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                          02-10-2025, 04:01 PM
                                        • ahoonid
                                          A1708 820-00840 No boot - trackpad clicks - 20V 0.55amp
                                          by ahoonid
                                          Hi everyone.
                                          I have MacBook Pro A1708 with a confusing issue.
                                          The laptop doesn't turn on. Strangely, the trackpad clicks and fan spins. Caps lock doesn't turn on and no chime.
                                          Initially, the amp meter didn't turn on at all on one of the usb c ports. On the other port, I got 20V and half an amp tho (no battery connected).
                                          I replaced the bad CD3215 chip and now it works as well. Both ports turn on with same amp readings.
                                          The initial issue however remains.
                                          No boot. No backlight. No chime. No keyboard. Only signs of life are clickable trackpad...
                                          05-10-2025, 04:19 PM
                                        • Noah Glasse
                                          LG 50PK590 - three clicks and steady red light, won't turn on.
                                          by Noah Glasse
                                          I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
                                          I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
                                          02-24-2025, 07:23 AM
                                        • joel warren
                                          Looking for some help please. Samsung UN75RU800DFXZA rebooting, no picture, clicks
                                          by joel warren
                                          TV was working fine and then just shutdown one day. It will not turn back on. I get a backlight for a little while, then it just clicks and won't fully boot.
                                          I took off the back panel and did the basic troubleshooting and it seems like it's a panel issue.
                                          The backlight will stay on if I disconnect either of the ribbon cables going to the panel. I've watched this video (https://www.youtube.com/watch?v=77tymvTJDxo) and am wondering if this could be the issue, just a bad cap on the panel.
                                          Any assistance is appreciated.
                                          01-27-2025, 06:31 PM
